spark plugs
Old Jun 15, 2009 | 06:35 PM
MP6's Avatar
MP6
Default spark plugs
so i gotta replace the fuel injectors. the dealer hydrolocked the engine with fuel and wont cover it so i hope there isnt a bent rod. but...what plugs do i replace with? it is a 92 lt1 six speed.
thanks
Old Jun 15, 2009 | 08:50 PM
383tpimachine's Avatar
383tpimachine
NGK tr6
Old Jun 15, 2009 | 09:00 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Never tried NGK but have heard good things about them. I use ACDelco RapidFire plugs. Stay away from the Bosch especially the +123 & 4. Unless you are heavily moddified, going all taht extra mile with the miracle spark plug is going to be a waste.
Old Jun 15, 2009 | 09:05 PM
STL94LT1's Avatar
STL94LT1
Ngk tr55
Old Jun 15, 2009 | 09:27 PM
StealthLT4's Avatar
StealthLT4
NGK TR55 or AC/Delco. And for fuel injectors, contact FICINJECTORS here on the forum. His name is Jon, he's great. or go to www.fuelinjectorconnection.com . He'll get you exactly what you need, for cheap, and even give you installation help over the phone!
Old Jun 15, 2009 | 09:46 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Wow... presume you've contacted the regional service rep ... ouch..
RE: plugs -- OEM is ACDelco platinum. However, because ACDelco doesn't make an iridium for our LT1 engines, and I had 3 ACDelco platinum plugs which had lost their 'pucks' (small platinum spot on the inside of the ground electrode).
Because of this, I choose to put in NGK TR55ix (iridium) in our 94 -- Been running good.
BTW, remember to use a torque wrench and a dab of anti-sieze.
Old Jun 15, 2009 | 10:42 PM
383tpimachine
sry ill be running tr6 since im gonna shoot a shot of juice but tr55 is fine for a driver
but if you want to spray 100+ then tr6 gapped .035 is the way to go
my local tuner swears by them in all his turbo/nitrous builds
Old Jun 15, 2009 | 11:54 PM
StealthLT4's Avatar
StealthLT4
also, be sure to buy a gapping tool and gap ALL the plugs yourself to 0.050". The AC/Delcos, at least, are supposed to come pre-gapped, but I had several that apparently got bumped during shipping, and were WAY smaller than 0.050"
Old Jun 16, 2009 | 12:08 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
NGK TR-55 Double Platinum.
Old Jun 16, 2009 | 12:27 PM
MP6's Avatar
MP6
thanks again guys. ill post a story when this whole disaster is over with. i have some issues to work out with it
To spark plugs
