I need to upgrade the Oxy Sensor on my 85 to a heated sensor to compensate for the slow temperature rise of my new Hooker 2149s. Does anyone know what year/make sensor I should buy? I'm going to tap off my fuel pump relay to provide the 12V the heating element uses.
Check in the forum's tech tips section. If I remember right, someone had posted instructions on installing the heated O2 sensor (because I printed out a copy thinking I would do it some time in the fututre). :)
? I've got Hooker 2151's ceramic coated and have the old one wire unheated sensors without any trouble, my A/F gauge works and updates quickly as soon as I fire it up. Is it setting codes or something?
Just curious why you would need to go from a $20 sensor to a $50 sensor.
