Hi guys,we just bought a Vortech v2 Supercharger for a friend of mine
He is doing a fresh build,TPI Based on a 4 bolt 1991 block.-
He also bought a set of 113 heads.-
This is the pic of the previous car where the supercharger was installed :
This is what we are getting :
My friend has the ZZ4 Cam and springs
Forged pistons and rods and fresh everything !
He is real happy about it and this will be a good learning experience.-
Ok here we have some doubts and im sure we are on the start of a long way.-
1 - Does he need a special timing retarder or something ?
2 - He bought FIC's Bosch III 22 lbs,does he need bigger injectors?
3 - He will do work on the 113's,what valve size is recommended for
this application?
4 - He will do work on the 113's,what combustion chamber size is recommended for this application?
5 - How is the proper way to reduce compression to make the supercharger work correctly ?
Do you guys have experiences with this Supercharger ?
More info here
Any advice / help is greatly appreciated !
as a point aside :
His 86 will get my 89 set of wheels (former bd2626's) and adapters
since im getting the Fikses mounted ! ! !
sammy
looks like we will be seeing alot of post from you on the progress. The 22's he got from us are too small for this.. I will credit him 100% on the right size.. Need to know how much boost? Is he upgrading the pump?
Jon
sammy
Jon
Thanks Jon !
We don't have no idea about the boost
is it something you can regulate at the supercharger or something ?
i'e always wondered how to regulate how much boost ...
I don't know if this comes with a new pump or not
Does he need a new pump ? Is it better to get a new one ?
Thanks again !
Thanks Jon !
Thanks again !
sammy looks to me its a decent street set up. the boost is built in by the pulley size. Since there is no intercooler or meth injection, i would guess its about 6 to 7 psi. I think the stock pump will be fine but upgrading to a walbro 255 with a wire kit would make sense. The kit has a boost referenced regulator already which you need. It raises fuel pressure 1 to 1 based on boost, this is all done by itself nothing for you to do but hook it up right, it looks like there is an external pump with the kit but I can't tell by the pic. If it is I would use it. Make sure you wire it to a fused circuit using a relay. I still like the in tank walbro better than running 2 pumps in series. The things cut and dry. Bolt it up.. The injectors, figuring 475 hp need to be 42lbs, so the 22 are NG. You will also have to send the chip out before you run the engine. So send it to someone now so its back in time, otherwise you will not be able to start it when the thing is ready. Make sure you give the tuner all the details of the mods. If you can get a hold of the orig owner try to get the boost numbers for the setup as I am only guessing on 6 to 7. I really don't think its much more without some type of cooling. You also need different spark plugs. have fun!
UPDATE: The whole thing comes with its pump.-
Yes this will be a good nice ride !!!!!!!
the SC bug bits me a bit ..but ..with my High compression and Hypereutectic pistons
i guess i won't do it on my 87..or maybe add a little little 4-5 psi boost....
The injectors may not be too small. Is this guy planning on using the FMU provided with the kit. If so you'll need to check and find out what the psi/# of boost increase is for the FMU as to which injectors you would use.
If he is not going to use the FMU then he would definately need bigger injectors. As most people will tell you the FMU is just a bandaid for not having the proper sized injectors and they do fail on occasion. It would be wise to upgrade the injectors, and the fuel pump while you are at it. A walbro 255lph should do him just fine.
if you are planning on having the ECM reflashed then you don't have to worry about anything to do the timing. With a supercharger the boost will be related to RPM so they can put it in the tune. If you want flexability to play with it then you would have to get an external box. A vortec BTM is a good choice, it will retard a certain amount for each pound of boost you have up to a certain amount.
The FMU is the device that raises fuel pressure depending on how much boost you are running. So instead of lengthening the pulsewidth of the injector is just increases the fuel pressure to get more fuel into the engine. Its the blue circle thing that has two braided steel lines comming out of it and one small rubber vaccume line. In the picture above its the part that is sitting in the fender. If you go to larger injectors then you don't need this part.
problem there is the 22 is enough for the stock 5.7 with the cam, head work etc, on N/A i'm afraid he will be short on injector. With the HP, the fmu will push the pump to max,, the injectors will probably max out which can cause a failure and some damage.. These guys are in chille, so parts are always not available except for a two week mail order. The guy looks like he has some bucks to do it right. So my suggestion would be to find out the boost of the blower, estimate the HP close, get a mail order tune and use the right size injector. As long as its tuned for the bigger injector he should be good to go. I really do not think that unit is more than 7 lb boost.
Thanks Jon and mn !
We'll find out what's the PSI when we get the SC here.-
Any recommendations on engine preparation or something ?
Valves ? or other issues,we are looking to make it right...
omg...the sc bug is biting me as well !
With a 3.5" pulley, an S-trim should make roughly 6-8psi between 5,000 and 5,600 rpm on an otherwise stock L98. More revs or a smaller pulley will result in additional boost.
For fueling a supercharged L98 MAF car you have a range of options available (ranked roughly in order of cost):
