Usually the factory specs are taken at the flywheel wereas when you dyno it is at the wheel. This means usually there is a percentage lost from the drive train back usually around 10-15% manual and 15-20 % auto is an accepted number.
Dynos will measure wheel HP, not flywheel like the factory rating, unless they are using some correction term already to get back to flywheel, which I doubt.
So you are probably in the ~290 chp range, 40 over the factory, which sounds reasonable given what you've done.
Thanks for the inputs. I did take the car to my first SCCA autocross a few weeks back and although it was one of the bulkier cars in the field, performed very well and I finished in the middle of my class. Not bad for my first time.
Sounds pretty healthy. Very similar to my #'s, but instead of chips and a cam I have long tube headers. I don't know if my #'s were corrected. That is just what was on the dyno sheet.
