Another coolant fan question
Old Jun 17, 2009 | 06:40 PM
flatbush862's Avatar
flatbush862
Default Another coolant fan question
I read through some of the threads on the cooling issues and the electric fans. From what I gather the ECM controls the fan operation - ( I have a 1990 )
My coolant fans are not turning on except with the AC is turned on. The temp comes up past 240 and the fans still do not turn on.
I have recently been checking codes with the A-B ports jumped out and the fans come on(?)
Could I have shorted something out?
Could it be a sensor? I previously changed the coolant temp. sensor
Or could it be 1 of the fan relays?
Any ideas??
flatbush862
Old Jun 17, 2009 | 10:26 PM
ol school's Avatar
ol school
Any ideas??
flatbush862
interesting, my 96 does the same thing , i have to run a/c year round
and use temp comtrol...
be nice if someone had an answer..
Old Jun 17, 2009 | 10:38 PM
gregs86's Avatar
gregs86
probly relay check it by unpluging relay use jumper wire between red/black & red wire if fan comes on relay is bad
Old Jun 18, 2009 | 12:10 AM
MK 82's Avatar
MK 82
What do you think turns on the fans when AC is on or in diagnostic mode?
Old Jun 18, 2009 | 12:37 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Any ideas??
flatbush862
It's not the fan relays as otherwise the fans would not come on at all.
Since during 'diagnostic' mode the fans came on, and went off after you pulled the 'jumper' (my assumption), doubtful you shorted anything.
Which coolant temp sensor did you replace (location/prongs)?
What dash gauge are you looking at when you noted '240' degree temps (digital or analog).
Old Jun 18, 2009 | 12:45 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Engine fan on is normal in the diagnostic mode for the C4 family.
Old Jun 18, 2009 | 01:09 AM
rodj's Avatar
rodj
And it is not the wiring from the ECM to the relays either since they work in diagnostic' mode.
As stated need to determine the actual engine temp when fans engage
Old Jun 18, 2009 | 04:31 AM
flatbush862
Yes the fans went off when I pulled the jumper.
I replaced the coolant sensor at the front of the intake manifold below the thermostat. I also replaced the temp. gauge sensor on the right head.
I have an analog gauge and I guestimated 240 as it approached the
"260" mark.
What tells the ECM to turn on the fans and could the ECM be a problem??..... I recently re-installed the stock PROM. I will be re-installing my PCM for less chip. But the problem started before the re-installation of the stock chip.
Old Jun 18, 2009 | 04:43 AM
rodj's Avatar
rodj
What tells the ECM to turn on the fans and could the ECM be a problem??......
Fan on/ off temps are programmed on the memcal.
Old Jun 18, 2009 | 06:54 AM
jeffp1167's Avatar
jeffp1167
Just take the threaded in plug out of the left head and put a thermal sensor for a f-body in, run a wire from it to both the relays ground wire. I think one is blue with white stripe and the other is blue with black stripe. that will end you cooling issues and take away control from the ecm. I gave up on getting the ecm on my 90 to run the fans now they work perfectly.
Old Jun 18, 2009 | 08:36 AM
rodj's Avatar
rodj
That is a job in itself
Old Jun 18, 2009 | 11:55 AM
flatbush862
What is the "memcal" ?
Old Jun 18, 2009 | 12:44 PM
rodj's Avatar
rodj
The chip that goes in the computer (ECM )
Old Jun 18, 2009 | 01:16 PM
jhammons01's Avatar
jhammons01
You are chasing Mods....there must be a reason your temps are reaching 240° to begin with......
I'd start with that first.
Making Mods or wondering why auxiliary cooling systems aren't coming on sooner is OK...but why are they needed?? That is the question that no one attempts to pose
Old Jun 18, 2009 | 01:43 PM
flatbush862
OK- so the "chip" meaning my PCM for less chip, signals the relays to turn on the fans. But what sensor tells the chip to tell the relay to tell the fan .. thats what I am trying to get at
I know of a Coolant Temp. Sensor in the intake man., a Temp gauge sensor in the right head .... is there another sensor "Fan sensor" - such as below - that independently indicates to the chip to turn the fan on?
http://hypertech.com/Products/Cool%20Fan%20Switch
where does this plug in?? and does it work??
Flatbush862
Old Jun 18, 2009 | 02:00 PM
jhammons01's Avatar
jhammons01
OK...more direct approach
Flatbush, have you pulled your 20 year old radiator and had it boiled out??
If there is sediment (and the common theme is that there is a ton of sediment in the bottom of the radiator) in the bottom of your radiator....what % of your radiators capacity is diminished by that section being essentially blocked off??
If your radiator's capacity is diminished by ~7% would that not account for some of your rising temps??? I just pulled a percentage number out as I have no way of knowing either way....I'm just asking the question most ignore.
Have you pulled the shroud off and seen what is in between the condenser and radiator?? Since the two coolant hoses and the two tranny cooler hoses are hooked up, not to mention way too many screws, many put this off yet it is most common in C4s
So yeah, mods would are great fun and you can list them in your signature...
Old Jun 18, 2009 | 03:42 PM
jeffp1167's Avatar
jeffp1167
Flatbush862
the CTS at the front of the intake manifold. I did everything you did replaced that, checked my prom which was a GM piece, did the self test thing. Then gave up ...... when you find out why yours dont work PM me
To Another coolant fan question
Old Jun 18, 2009 | 04:01 PM
flatbush862
Jhammnd-
Yes I agree that the root cause of the overheating could be in the radiator. But it still does not address why the fans are not coming on.
I will flush out the radiator and take it from there.
Old Jun 18, 2009 | 04:26 PM
jeffp1167's Avatar
jeffp1167
Jhammnd-
if CTS is doing it's job, fans worked before so prom/clapack probably not the problem. Then the only thing left is a faulty ecm.
Old Jun 18, 2009 | 05:10 PM
gw962's Avatar
gw962
Flatbush, if you have the C68 (electronic AC) you can verify what the sensor is reading by pushing both fan buttons until -00 shows on the AC display. Use the right button to scroll to -16 and push "AUTO". This will display the coolant temp in celsius, so you'll need a conversion table.
According to the FSM, the primary fan should activate at 226F (108 C) and the secondary at 239F (115C).
