AFR Heads
Old Jun 18, 2009 | 01:29 AM
ken93vette's Avatar
ken93vette
Default AFR Heads
After a hack porter turned my heads into swiss cheese I have to purchase new heads.
I have decided to get AFR 180's. They come with guide plates and say you should use standard rollers.
I already have a set of 1.6RR self aligning and I hate the thought of buying another set.
I have had three opinions;
1. Machine shop said take the guide plates and replace with 1/8" washers.
2. AFR salesman #1 said use the guide plates make sure pushrods are properly sized so not to wear guide plate.
3. AFR salesman #2 absolutely no, buy new RR.
Anyone have any experience with this?
Ken
Old Jun 18, 2009 | 01:48 AM
cv67's Avatar
cv67
St. Jude Donor '05
The guidplates are about the same thickness as a ARP headbolt washer. Dont know why this wouldnt work. Or just leave the guidplates on and use a non self aligning rocker either way. If I was using a large by huge cam I would use guidplates.
Old Jun 18, 2009 | 02:01 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If you said something about a big cam/high-rpm application #3 is best. Otherwise, I would agree with Cuisinartvette and say options 1 & 2 are correct. Washers should work. If hardened pushrods were used under your self-aligning rockers, I'd think you could keep the guideplates.
Old Jun 18, 2009 | 08:27 AM
96GS#007's Avatar
96GS#007
You absolutely can not use self-aligning rockers on heads with guide plates.....well....at least not for long since in no time you'll be pulling the heads due to worn valve stem tips and metal shards in the engine.
The first thing you need to do is verify that the roller rockers you have will work with the specific valves in your heads. Some of the AFR heads use 8mm LSx style valve stems. If they will work, then you can shim under the rocker arm stud as the machine shop suggested or buy new studs.
In addition to the above, self-aligning rockers generally use a 3/8" stud while most aftermarket heads including the AFRs use a 7/16" stud. In other words you'll need new studs anyway if this is the case.
Personally I would sell those rockers and buy new.
Old Jun 18, 2009 | 08:28 AM
ken93vette's Avatar
ken93vette
Thanks guys I will let you know how it turns out.
Probably be a couple weeks as I have to wait for the new heads to arrive.
Old Jun 18, 2009 | 10:08 AM
rickneworleansla's Avatar
rickneworleansla
Old Jun 18, 2009 | 12:38 PM
tpi 421 vette's Avatar
tpi 421 vette
Originally Posted by 96GS#007
new studs.
AFR 180 and 195's come standard with 3/8" studs. It's the bigger 210, 227, ect heads that come with 7/16" studs. The smaller heads can be upgraded to 7/16 studs.
Personally, I would sell your self aligning rockers, and buy non self aligning rockers, and use the guide plates.
Old Jun 18, 2009 | 03:48 PM
GREGGPENN's Avatar
GREGGPENN
AFR's default with 3/8" studs. 7/16" studs are an option for a few more dollars.
Old Jun 19, 2009 | 02:37 AM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Self aligning rockers can not be used with the Eliminators if you omit the guideplates as they are meant to self align over an 11/32 valve, not an 8mm. Could you use them with guideplates....honestly perhaps you could if the guideplates kept the rockers properly located but it seems kind of hack though....I would rather do it right with a quality non self aligning rocker. Jegs has some private label Crane knockoffs that are very affordable and you can sell the rockers you own now.
Ported stock head?....not in the same league
As I feel like a guy doing this sometimes I will simply leave it at that.....
-Tony
Old Jun 19, 2009 | 03:20 AM
GREGGPENN's Avatar
GREGGPENN
Consistent and accurate information might help prevent some of your frustration. As seen in the OP, two conflicting answers were given by your guys.
I had the same issue regarding another question. When I asked about the need to upgrade to 155# springs for a 5000 rpm application using an XFI cam profile, you said it was "a necessity". (I still have that email). However, both your tech guys and others in both CF and TGO forum said it was not.
After trying to pass your recommendation on to others wanting to use XFI cams at a higher 5800 rpms, I was heavily challenged. The resulting consensus was that I would not have "lost valve control" in my application -- and that I didn't "need" the upgrade. Subsequently, three of us called AFR tech for a definitive answer. AFR tech guys reiterated that 155# springs were "unnecessary" under 5800 rpms.
Hopefully, you'll take this msg and consider creating a more unified voice from your tech department.
gp
BTW: I apologize to the OP. I was also told self-aligning rocker would work on AFRs. I didn't go with that option because I thought non-aligning were going to cost less.
Old Jun 19, 2009 | 09:29 AM
neat's Avatar
neat
I've got a pretty nice set of Trick Flow heads for sale in the for sale section.
Old Jun 19, 2009 | 09:33 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
-Tony
That's good to know
Old Jun 19, 2009 | 10:42 AM
JAKE's Avatar
JAKE
-Tony
Congratulations on AFR's 1st place showing in the new GM HIGH-TECH PERFORMANCE magazine LT1 HEAD SHOOT OUT!
Jake
West Point ROCKS!
Old Jun 19, 2009 | 02:21 PM
GREGGPENN's Avatar
GREGGPENN
Josh,
I think we're talking about an LT1 motor here. Yours are for an L98. (Note the OP has 93vette in his ID.)
A more relavent contribution would be your direct comparison of AFR heads to another option. The heads you're selling are part1 of the comparison. The AFR heads are going on now, right?
Old Jun 19, 2009 | 03:37 PM
neat's Avatar
neat
Yes, AFR head install is under way. It's tough right now because I can only work on the car in the middle of the night. It's been hot as Hell here lately, and 95 degrees/95% humidity, in a non-air conditioned garage is not my idea of fun. However, late at night it's tolerable.
I'm hoping to get close to finishing it this weekend.
I didn't see where he said what year it was, and I'm too lazy to click profiles. It's also a shameless plug for my heads.
To AFR Heads
