93 engine/trans removal
Old Jun 19, 2009 | 04:41 PM
LOTOF TOYS's Avatar
LOTOF TOYS
5th Gear
Default 93 engine/trans removal
Can the lt-1 engine/6sp trans be removed at the same time"connected" or is it easier to remove the trans frist? Randy
Old Jun 19, 2009 | 04:51 PM
farscape1a's Avatar
farscape1a
you can pull the engine and trans at the same time, you'd have to remove the hood. but that can be a monster to realign when you put it all back together. it may be easier to remove the trans from the engine first...
