VATS module
Old Jun 20, 2009 | 04:33 AM
spanishvette86's Avatar
spanishvette86
Default VATS module
Hi all.
I will buy a new VATS module. Do i need the key code?
When i test it with polymeter it says 11,86 (20K scale). That is 11860 (key 15) or 1186 (key 5).
I do it in 20k scale because my polymeter is 2K, 20K, 200K, 2000K .
This is an 86 vette.
Thanks !!
Old Jun 20, 2009 | 05:27 AM
rodj's Avatar
rodj
I don't think will find a new one and any 2nd hand ones will be programmed to one of the 15 key codes.
http://forums.corvetteforum.com/1568459145-post33.html
Being where you are maybe you could bypass ?
http://www.joestradingpost.com/vats/
Old Jun 20, 2009 | 05:37 AM
jeffp1167's Avatar
jeffp1167
when you buy the new decoder box the first key which it reads is the code of what it will be. That is if you can find a new one, I bought one quite a few years ago and it was like 250 bucks if memory serves me right.
Old Jun 22, 2009 | 04:59 AM
spanishvette86
Thanks for your time. I won´t to bypass it, VATS sucks, but it´s another problem for thiefts
Thanks!!
I´ve seen a new one at Ebay. It´s 70 $.
Regards from Spain
To VATS module
