1 Headlight delayed on closing
Old Jun 20, 2009 | 03:56 PM
3D-Aircrew's Avatar
3D-Aircrew
Default 1 Headlight delayed on closing
They both open fast together but when I shut them off the left one closes right away but the right one closes about 30 seconds later.
It sounds like it doesn't get power until then.
86 vert
thanks
Old Jun 20, 2009 | 06:14 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You could check that with a volt meter.
Old Jun 21, 2009 | 10:23 AM
3D-Aircrew's Avatar
3D-Aircrew
Default I'll check it out
It's safe to open and close the headlights with the hood open right?
If the voltage doesn't appear until when it closes that means what?
I guess if the voltage is present from the time I switch the lights off then the motor's dragging?
Old Jun 21, 2009 | 10:40 AM
aminnich's Avatar
aminnich
Yes, you can operate the headlights with the hood open. Listen carefully to see if the right side motor is running right away, but just not closing. If that is the case it is the gears in the HL motor. Otherwise it is likely one of the relays in the headlight control module.
Old Jun 21, 2009 | 10:46 AM
guido7834's Avatar
guido7834
I had a similar problem with my 87. If voltage is OK, try slightly turning the manual ****. If it opens, then it could be the motor jamming or gears. My problem was the magnet inside the motor was broken in half and jamming the motor from spinning. I super glued it back together, and then epoxied it back to the housing. Also replaced the gears while I had it apart. works fine now. Of course, you have to take it all apart to see what is going on inside so I would make sure all is OK with it getting power first.
Old Jun 21, 2009 | 11:52 AM
3D-Aircrew's Avatar
3D-Aircrew
Default No ... there's always a 20-30 second delay
Doesn't matter if the car is running or not.
Where abouts is the headlight control module?
Old Jun 21, 2009 | 11:55 AM
aminnich's Avatar
aminnich
I meant the electric headlight motor, not the engine. The module on mine (1995) is in the well just forward of the left front tire.
Old Jun 21, 2009 | 12:15 PM
3D-Aircrew's Avatar
3D-Aircrew
I knew that ... just thought it was important.
Old Jun 21, 2009 | 12:35 PM
jhammons01's Avatar
jhammons01
If there is an audible grinding sound, you may have the plastic gear trouble......if you can push the headlight and get it started and then it completes its task on it's own then it is electrical which includes the Motor being old and weak.
Old Jun 23, 2009 | 02:31 PM
3D-Aircrew's Avatar
3D-Aircrew
Default Search is my friend
'84 to '87 has the three relay setup not the expensive headlight control module of the later C4's.
Would anyone have the schematic for the headlights for an 1986?
Thanks in advance
Old Jun 23, 2009 | 06:40 PM
3D-Aircrew's Avatar
3D-Aircrew
Default 2 control relays 1 isolation relay
There are 2 motor control relays 1 isolation relay setup using relay ladder logic. I don't even know where they are located. Anyone?
Old Jun 25, 2009 | 10:39 AM
3D-Aircrew's Avatar
3D-Aircrew
Default found tech instructions
For the 2 headlight motor control and isolation relay on 84-87 -- MAM sells the relays too.
http://content.mamotorworks.com/pdf/601723.pdf
Old Jun 25, 2009 | 11:18 AM
flynn508's Avatar
flynn508
I have a similar problem on my 86, but I know that it is just the housing rubbing on the body. There is a little 'rash' near the right headlight on the bumper; the PO obviously hit something jsut enough to twist the housing slightly. It opens just fine, but closes a little slow and a little late. Sometimes it wont close at all and have to push it a little with my hand and then it closes right up. Myabe something to check; I always try to go for the easy solution first before ripping stuff apart!
Old Jun 25, 2009 | 02:39 PM
3D-Aircrew's Avatar
3D-Aircrew
Default I'm going to try all the simple fixes first
Probably not get to it before the weekend.
To 1 Headlight delayed on closing
