Water Pump for LT1
Old Jun 21, 2009 | 11:38 AM
LBYRNES's Avatar
LBYRNES
Default Water Pump for LT1
Does anyone make a better water pump for the '93 LT1 than the GM pump?
I'm rebuilding my LT1 and would like something a little more reliable.
Old Jun 21, 2009 | 11:50 AM
STL94LT1's Avatar
STL94LT1
Unfortunately, no.
Old Jun 21, 2009 | 12:09 PM
ChrisWhewell's Avatar
ChrisWhewell
Originally Posted by STL94LT1
Unfortunately, no.
Off topic perhaps a little but check this out
http://www.patentsearcher.com/goose.jpg
There was a bunch of casting flashing at the location the arrows point to.
I measured the smallest x-sectional ID before I ground it and afterwards and calculated a 13% increase in cross sectional area. To the extent it was formerly restrictive, it's less restrictive now. I'm running a 160 stat. When its 85 deg outside my crate operates 169-171 and yesterday when it was 101 deg outside it ran @ 174. I'm using the Meziere. Another area are the bends in the block where the coolant enters from the pump - horrible bends with a big slug of iron in the way. When I did the pump swap on my 93 last week I stuck my fingers in those holes and felt the blockage. On the bare block I'm working on, I made niceties out of those bends. Nice smooth curves w/no impedance now.
Old Jun 21, 2009 | 02:37 PM
slovill's Avatar
slovill
I don't know if they have one for the '93 LT1, but I installed a Stewart stage 2 on my mid year, included the recommended thermostat, and it is great.
Check them out here
Good luck!
Old Jun 21, 2009 | 02:43 PM
aminnich's Avatar
aminnich
If you go to the Meziere HD electric pump you never have to worry about it leaking and destroying the opti. I have had mine on for two years with no problems. I carry a spare relay and an emergency jumper to just by pass and direct wire it in case of emergency but have never had to worry about it.
Old Jun 21, 2009 | 07:50 PM
Mojave's Avatar
Mojave
I have a stock water pump on my 383 and track the car with no cooling problem. I'm not a big fan of the EWP. I don't see any reason to upgrade from the stock one, it works well (when it's not leaking).
To Water Pump for LT1
