Correctly Aligning Crank/Hub and Pulley
Old Jun 22, 2009 | 12:24 PM
JAKE's Avatar
JAKE
Default Correctly Aligning Crank/Hub and Pulley
1996 Vette LT1
Since this is only the 2nd LT1 I've built and because I can't find Volume 2 of my FSM set, I want to check my memory on the alignment just to be sure I do it right.
When installing the hub, I'm supposed to align the DOT on the hub with the keyway groove in the crank snout. then when installing the damper/balancer/pulley, I'm supposed to alight the cast-in arrow with the hub's DOT.
Am I correct? I want to prevent any chance of a vibration in my son's 96 LT1Vette.
Thanks for any help.
Jake
Old Jun 22, 2009 | 01:37 PM
pianoguy's Avatar
pianoguy
Can't confirm the crank to hub orientation, but the pulley's arrow lines up with the raised area of the hub. And if I remember correctly, it will only bolt up one way - the bolt holes aren't evenly spaced.
Old Jun 22, 2009 | 01:46 PM
96GS#007's Avatar
96GS#007
With #1 cylinder at TDC, the cast in arrow on the crank hub should be at 12 o'clock. The balancer will only fit on the hub one way, so you don't have to worry about orienting the balancer.
To Correctly Aligning Crank/Hub and Pulley
