Hey everyone,
Ive been looking around and my SM does not clarify the tools needed for the hub replacment. I have an 85 and im trying to figure out what size Torx socket is needed to remove the main hub. If anyone can remember what size they used that would be great, that way i can just buy one socket! Any other advice would be appreciated as well.
Bingo. Also, I did mine just fine without removing the half shafts. You just have to rotate them between removing the 3 T55 bolts, as you can only get to them when the outboard U-joint is in a certain position. Probably easier than removing them...
One of them "wobbler" extensions helps out as well.
Kind of like a universial joint for sockets
Two "wobblers" together work great for the top TORX bolt on the backside.
Don't need to remove the half-shafts. But good time to inspect U-joints
looks like i double posted here... sorry. But do you know where i can find the washers? Mine are definitely worn and all my local parts stores don't know what im talking about, even the Chevy Dealer.
Thanks,
Brian
Dealer or GMPartsDirect should have them. Did you give your dealer the part number and they still could not find it?
