Oil pressure issues.....
Old Feb 10, 2002 | 12:44 PM
OrangeC4's Avatar
OrangeC4
Default Oil pressure issues.....
My oil pressure has been acting strange for about the past couple of weeks. At cruising on the freeway it some times fluctuates between 60 and 70 but most of the time it is stuck at 80. Then sometimes after I drive the car some what hard and then come to a stop, it drops to around 4 and the little red light comes on on the gauge. If I rev the engine it then starts going back up to about 45, where it has been at idle the past couple of weeks. Any ideas on what the problem might be?
Old Feb 10, 2002 | 12:59 PM
scorp508's Avatar
scorp508
Mine does that if I've burned some oil. I would check the oil level.
Old Feb 10, 2002 | 02:27 PM
1MoorTym's Avatar
1MoorTym
Default Re: Oil pressure issues..... (OrangeC4)
Definitely check the level, but I'd also get a mechanical gauge on there to see whats going on. 4psi is ng and you really shouldn't have 45 at ide (warmed ?).
Could be sending unit or gauge but using another gauge as a reference will get you a lot of information. Have you changed oil weights or filters recently?
Old Feb 10, 2002 | 02:28 PM
scorp508's Avatar
scorp508
Default Re: Oil pressure issues..... (1MoorTym)
Why not? I typically have 55-60psi at idle after an oil/filter change. :)
Old Feb 10, 2002 | 02:34 PM
OrangeC4's Avatar
OrangeC4
Default Re: Oil pressure issues..... (scorp508)
My oil is a low, and it is about time for an oil change so I am going to change it today. We'll see if that fixes the problem.
Old Feb 10, 2002 | 02:41 PM
1MoorTym's Avatar
1MoorTym
If you got 55-60psi at idle (hot) with a stock pump and the mileage you've got on that engine, thats great. Guess you're pegging that thing at 3500rpm.
I typically see 20-25 hot at 800rpm on my 89 with 5w-30.
Old Feb 10, 2002 | 02:44 PM
scorp508's Avatar
scorp508
I sure don't, but the previous 3 owners probably did. They were all cruisers that spent the first 98k miles breaking it in for me. :) At hot idle I get about 50psi.
Old Feb 11, 2002 | 01:42 AM
OrangeC4's Avatar
OrangeC4
Default Re: (scorp508)
Low pressure is fixed, but still have the issue of being stuck at 80.
Old Feb 11, 2002 | 02:09 AM
scorp508's Avatar
scorp508
Default Re: (OrangeC4)
I just remembered this. If I am remembering correctly, being stuck at 80 is a dead giveaway for a bad oil pressure sending unit. Get that baby replaced or check the connection if it is intermittent.
Old Feb 11, 2002 | 02:19 AM
OrangeC4's Avatar
OrangeC4
Thanks for all your help with this problem, I have tomorrow off so I am going check the sending unit. How exactly can I tell if it is bad?
Old Feb 11, 2002 | 03:00 AM
scorp508's Avatar
scorp508
Page 8A-82-14 in my '87 electrical diagnosis service manual supplement has a test for constant high pressure.
K: OIL PRESSURE DISPLAY INDICATES HIGH PRESSURE CONSTANTLY
Connect: Fused Jumper
At: Oil Pressure Sender Connector
Condition: Ignition Switch RUN
Jumper Between: (TAN) & Ground
Correct Result: Oil Display indicates 0 psi (0 kPa)
For Diagnosis Otherwise: See 1
Correct Result = Replace the Oil Pressure Sender
1 = Check TAN (31) wire for an open. If the TAN (31) wire is OK, replace the Instrument Cluster (see Section 8C)
Here is the test for the opposite.
J: OIL PRESSURE DISPLAY INDICATES LOW PRESSURE CONSTANTLY
Disconnect: Connector
Action: Disconnect Oil Pressure Sender Connector
Correct Result: Oil Pressure Display indicates 80 +/- 3 psi (550 +/- 30 kPa)
Correct Result = If the result is correct, replace the Oil Pressure Sender
1 = Check TAN (31) wire to Instrument Panel for a short to ground. If the TAN (31) wire is OK, replace the Instrument Cluster (see Section 8C).
Old Feb 11, 2002 | 03:06 AM
scorp508's Avatar
scorp508
In short it means this. :)
Ground the tan wire coming out of the pressure sender. Turn the key to run, and the gauge should read 0 psi. If it does, replace the sender. If it doesn't, then you do 1. Now I am not positive if it means to do this while the tan wire is still connected to the sender or not. That I can not tell you as I am not positive.
As you can see from the LOW pressure test though, disconnecting the wire should bring up 80 psi +/- 3 psi on the gauge automatically.
I hope that helps somewhat.
Old Feb 11, 2002 | 03:17 AM
OrangeC4's Avatar
OrangeC4
Thanks Scorp, I'll let you know how it goes.
Old Feb 11, 2002 | 03:19 AM
GlockLT4's Avatar
GlockLT4
Cool scorp.. i'll do that to test mine.
Old Feb 11, 2002 | 10:17 AM
scorp508's Avatar
scorp508
Default Re: (Glock'94)
I have no idea if that works for a '94.
Old Feb 11, 2002 | 02:57 PM
GlockLT4's Avatar
GlockLT4
I'll check the service manuals. Do you recall if your sensor has 3 wires scorp?
Old Feb 11, 2002 | 03:09 PM
scorp508's Avatar
scorp508
I've never looked at it, but I believe the service manual only showed the one TAN wire coming off of it which makes sense to me for being a pressure sender.
To Oil pressure issues.....
Old Feb 11, 2002 | 04:08 PM
GlockLT4's Avatar
GlockLT4
It's different then. Mine has more than just one wire coming out of it. Not sure why though. I bought a new one to try, and I would like to test the one on there currently before i put the new one i bought on.
Old Feb 11, 2002 | 04:29 PM
Nathan Plemons's Avatar
Nathan Plemons
A friend of mine bought a 95 Z-28 that had over 100k miles on it, the owner had badly mistreated it. When I drove it home for him I noticed that oil pressure would go up and then stick, it wouldn't go down until you shut the
car off. That night we changed his oil to Mobil 1 synth, 15 minutes later his gauge problem was fixed.
The old oil looked like crude, it was about as thick as syrup while warm. NASTY. We pulled a valve cover off and were scared, we put it right back. He's got spun bearings in his future. The motor looked just like yours Glock, and he's starting to have low idle oil pressure issues. He has it in his head that he'll just change the oil pump. I mean damn, if you're gonna take it that far apart at least do a budget or performance rebuild. He KNOWS how nasty the motor is.
Old Feb 11, 2002 | 04:30 PM
GlockLT4's Avatar
GlockLT4
Default Re: Oil pressure issues..... (Nathan Plemons)
Yup.. he needs a 383 :yesnod: :yesnod: :yesnod: :yesnod:
