What is this sensor?
Old Jun 22, 2009 | 05:48 PM
popkid's Avatar
popkid
Default What is this sensor?
What is this sensor? (on '88 L98)
Drivers Side Between #1 and #3 Plug Leads
Cheers,
Paul
Old Jun 22, 2009 | 05:58 PM
Crzyfrlss1's Avatar
Crzyfrlss1
On top...air pump check valve for the cats, it makes sure the air only flows in one direction.
Below...knock sensor.
Old Jun 22, 2009 | 06:13 PM
popkid's Avatar
popkid
Thankyou! Love these forums , can always reply on someone helping you out quickly!
It is the knock sensor I was referring to btw.
I had a hunch that was what it was, but my Haynes manual helpfully only mentions the location of the one on the right hand bank and then states there is another one but doesn't say where...
I noticed it was there as there was no wire attached to it so I had a hunt around and found the green/white wire hanging around off the harness. I guess having one disconnected doesn't trigger a CEL...
Thanks Again,
Pauly
Old Jun 22, 2009 | 06:15 PM
Crzyfrlss1's Avatar
Crzyfrlss1
You're welcome...I agree this forum is a great resource for corvette owners.
Just a note though, I think that wire is supposed to be run under the manifold instead of over it...
Old Jun 22, 2009 | 06:20 PM
popkid's Avatar
popkid
Thanks again, I'll change it.
Pauly
Old Jun 22, 2009 | 06:51 PM
popkid's Avatar
popkid
Hmmm, seems it may be the auxiliary fan temp sender, rather than a knock sensor...
See:
http://forums.corvetteforum.com/c4-t...post1564648759
Wouldn't have made any difference being off, my car never gets hot enough to need it....
Pauly
Old Jun 22, 2009 | 07:02 PM
Crzyfrlss1's Avatar
Crzyfrlss1
I dunno
It sure looks like a knock sensor to me.
I'm pretty sure some years of C4's have 2 knock sensors, someone needs to correct me if I'm wrong.
Actually...I'm gonna go look in AllData right now and find out [I]exactly[I] what that is.
Old Jun 22, 2009 | 07:05 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
that is the aux fan switch. it comes on with temp.
the knock sensor is in the block drain fitting just within an inch or so of the oil pan. and it is on the right side by the starter.
Old Jun 22, 2009 | 07:07 PM
bill mcdonald's Avatar
bill mcdonald
yeah that looks like a fan sensor, being it is in the head.
rather it turns the fan on and off, or sends the info to the dash. I cant remember which is which and what years have what.
The knock sensor is usually in the block, on the passenger side.
Old Jun 22, 2009 | 07:08 PM
Crzyfrlss1's Avatar
Crzyfrlss1
And....we have a winner.
You win.
Old Jun 22, 2009 | 07:26 PM
popkid's Avatar
popkid
Thanks again,
Though doubt it being plugged/unplugged will ever make much difference here! Temp today in my town was 64 degrees, which qualifies as a nice summers day....
So like I said, No cooling issues on mine, primary fan runs as it should around 223 or wherever, and temp drops then, so it never gets hot enough to need aux in any case... I actually didn't know there was an aux fan until today... :o
Only time I can see it running is if a head gasket fails or something...
Pauly
Old Jun 22, 2009 | 07:43 PM
MikeC4's Avatar
MikeC4
Originally Posted by popkid
Thanks again,
Pauly
64 degrees !!!!! You lucky Brit !! About 102 degrees here in Texas....I am moving to Warwickshire..... I need directions though !!
Old Jun 22, 2009 | 07:55 PM
popkid's Avatar
popkid
East... a lot...
Wikipedia: Royal Leamington Spa, Warwickshire
Seriously, I think the official record temperature EVER in the UK is around 102 degrees! Most summers we will have no days even in the 90s...
Why do you think we're all so pale looking!
Pauly
To What is this sensor?
