Heater core replacement
Old Jun 22, 2009 | 09:44 PM
Paul Cap's Avatar
Paul Cap
Default Heater core replacement
Does anyone know what the flat rate time is for changing the heater core on a 93 coupe?
Old Jun 22, 2009 | 09:54 PM
jmalez's Avatar
jmalez
not the rate but i know a guy at work who just had his 94 c4 heater core changed at the dealer and bill was $900.00
Old Jun 23, 2009 | 12:42 AM
Movnviolation's Avatar
Movnviolation
Thats about right. Someone might do it cheaper, but not much. The job is doable by yourself but is a pain in the ***. It took me three days, about 6-8 hrs total on my 89. I had to walk away several times, and only threw 3 flashlights. A lot of bad words and it was done.
Might as well jump in there and work on them if you are going to drive them. A whole lot cheaper!
Old Jun 26, 2009 | 01:57 PM
aheaton's Avatar
aheaton
Alldata says 5.0 hrs. Warranty time is 2.5. Hope that helps.
Old Jun 26, 2009 | 03:30 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I've done several in my shop. They're not that bad. If you haven't done it before get a factory shop manual or an Alldata print out. Take your time and don't force anything.
Old Aug 21, 2009 | 03:37 PM
carllangford's Avatar
carllangford
So what did you wind up doing?
Old Aug 23, 2009 | 07:59 PM
quickcat's Avatar
quickcat
I say BS on those times. It took me two days to do it last week and I imagine I could do it in 8-10 hours the next time but 2.5 hours is about enough time to install a heater core bypass!
I realize nobody is personally claiming that it can be done that fast but it is silly that the time is so short.
Matt
Old Aug 29, 2009 | 11:49 AM
turbotim23's Avatar
turbotim23
I have to replace the heater core in my 93 coupe. I've seen how you can do it the fast way, where you take the passenger seat out and lay on your back and r&r the heater core from the bottom without removing the dash . I need to know if doing it the fast way is possible on a 93 or was that only for other year corvettes? Thanks Tim
Old Aug 29, 2009 | 07:00 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
If I remember right, at the factory they put the heater core on a steel table & then built the car around it.
Old Aug 29, 2009 | 09:55 PM
89corvettedriver's Avatar
89corvettedriver
3rd Gear
I am 16 and replaced it in my 89 it was a very hard task..the dealership was charging 200 for the new core and bout 1000 for the work
Old Aug 30, 2009 | 02:47 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
My local vette shop charged my 6 hours for the job.
To Heater core replacement
