Any tricks/recommendations for replacing intake manifold gasket?
Old Feb 14, 2002 | 03:34 PM
Guest
Guest
Posts: n/a
Default Re: Any tricks/recommendations for replacing intake manifold gasket? (h rocks)
By all means, drain the coolant down. My Accel manifold has a runner bolt hole on the drivers side, the bottom hole nearest the firewall, that is drilled into the coolant passage. Use some RTV for these bolts. HTH
