heated O2 sensor questions
Old Feb 10, 2002 | 07:55 PM
Gogobig92's Avatar
Gogobig92
Default heated O2 sensor questions
I have a 92 coupe and its sensors are not heated , and i need heated O2 sensors, so , I called t.p.s and they have a 3 wire one for 60$ a piece, so I called a local parts store for 94 heated ones, and they had them for 40$ a piece, but a friend of mine can get them free, my question is will they work and if so how do I wire them, what wires go where, which is signal, which one is a 12volt source, and which 2 are grounds, thanks any one who can tell me.. :chevy :crazy: :chevy
Old Feb 10, 2002 | 09:14 PM
HighHopes85's Avatar
HighHopes85
Default Re: heated O2 sensor questions (Gogobig92)
For a 3 wire sensor, the black wire is the signal and the 2 white wires are for chassis common and +12. It doesn't matter which on of the white wires goes where. The heater for the O2 draws about 1 amp, so if you feel the need add a fuse or relay, do so. -Matt-
Old Feb 11, 2002 | 11:14 AM
DarkRose94's Avatar
DarkRose94
Default Re: heated O2 sensor questions (HighHopes85)
I didn't know that the car had three of them under it :eek: I noticed them when I was under it yesterday.
To heated O2 sensor questions
