1993 auto trans shifter
Old Jun 25, 2009 | 12:59 AM
93vetteflies's Avatar
93vetteflies
6th Gear
Default 1993 auto trans shifter
The button on top of the shifter depresses but will not return. This prevents me from removing my key from the ignition and also the shifter does not stop in any of the required stops. I dissassembled the console to find the problem and found the spring that allows the button to actuate properly had broken. I can not order it from G.M. because it is not an orderable item and the entire mechanism is not even an item that G.M. even carries any more. Salvage yards in the area do not have any parts either. Any one else run into this problem? Any suggestions?
Old Jun 25, 2009 | 01:49 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Contact Coastalvette.com or vette2vette.com, both will likely have the part.
