643 and 347 heads?
Old Jun 26, 2009 | 02:02 PM
bigwave71's Avatar
bigwave71
Default 643 and 347 heads?
does anyone have the specs on the 643 and 347 heads? i have the 347s and wanted to know if there was any advantage in the 643s.
Old Jun 27, 2009 | 09:01 PM
bigwave71's Avatar
bigwave71
Old Jun 27, 2009 | 09:03 PM
farscape1a's Avatar
farscape1a
talk to the guys at advanced induction. they port heads with those ending numbers. i have a set of 347 heads myself. even if you're not looking to port, they probably can give you a good explanation.
Old Jun 27, 2009 | 11:13 PM
cv67's Avatar
cv67
St. Jude Donor '05
643 is alright one regardless of naysayers.
Stock #s are on top, bottom is after the first pass to see where they were at (lousy low/mid#s tell that) before anythign furher was done.
Wound up scrapping them and going aftermarket. For what he wanted by the time the grinding was done, big valves, etc etc it was less to go to a better head that would still outperform the LT.
Not a big fan of chopping a facotry head to death to get a big # imo it ruins the port characteristic.
For a mild or moderate build its worthwhile depending on use/$$. Not sure Im qualified to say that though.
Pretty easy to get the 250/180-190# out of them though. Would work great with a hotcam.
Old Jun 28, 2009 | 12:01 PM
ChrisWhewell's Avatar
ChrisWhewell
Stock #s are on top, bottom is after the first pass to see where they were at before anythign furher was done. Wound up scrapping them and going aftermarket. For what he wanted by the time the grinding was done, big valves, etc etc it was less to go to a better head that would still outperform the LT.
I appreciated a couple things Elliott wrote in this one and some of the follow-up replies:
http://web.camaross.com/forums/showthread.php?t=411824
Old Jun 28, 2009 | 01:08 PM
cv67's Avatar
cv67
St. Jude Donor '05
Read up to about page 4 where it turned into another bashfest.
Old Jun 28, 2009 | 01:26 PM
ChrisWhewell
Saw that . .
I'm with Lloyd though, I didn't see him as bashing anyone, just expressing some valid points.
I haven't touched the cross sectional areas yet on these runners - waiting to learn more, may take me decades .....
BTW, nice grinding work you did on a couple pics you posted.
To 643 and 347 heads?
