91 L98 engine stopped
Old Jun 28, 2009 | 01:17 PM
nysec's Avatar
nysec
Default 91 L98 engine stopped
Cruising @ 70-75 mph with AC temperature gauge registering a little over mid range. Ambient temperature about 100. Usually registers below mid range without AC. Slowing down in traffic and stopping for lights the temperature would move to about ¾ range. Turning off AC and moving up to 60-70mph the temperature gauge would go back to little over mid range with AC on. This type of driving over a three-hour period. Then after cruising @ 70mph AC for about 45 minutes temperature gauge a little over mid range engine begin to loose power and stopped. It would crank right up and idle for 30 seconds to a minute then stop. After about 1 hour it started right up and I drove it about 10 miles to a shop without any issues. Had a tow service haul it home. It seems to running OK now. But I’m a little leery about driving it until I know what caused the problem.
Would the higher than normal temperature ranges have caused the engine to stop?
I have read Lars Grimsrud’s article on cleaning the radiator and it does need cleaning which I will do today. Will also check the fans. Should I check anything else while I’m at it?
Any advice greatly appreciated.
Jim
Old Jun 28, 2009 | 01:50 PM
Demonic85's Avatar
Demonic85
Check the fuel pressure to see if the its a dying fuel pump. If its never been replaced I would consider this. Check fusible links to make sure nothing is getting burnt up, especially around the starter.
Old Jun 28, 2009 | 11:23 PM
SSWEET's Avatar
SSWEET
Same thing happened in my 88...It ended up being the fuel pump.
Old Jun 30, 2009 | 11:59 AM
nysec's Avatar
nysec
Thanks for the reply. Removed radiator and cleaning it was really dirty. It's a wonder it didn't overheat all the time. Will check FP and advise.
Thx
Old Jul 3, 2009 | 09:08 AM
nysec's Avatar
nysec
Default 91 L98 Stopped
Radiator removed, cleaned, reinstalled. Drove in city traffic for an hour ambient temp about 95 temp gauge well under mid-range and no engine issues. Will check the fuel pressure this weekend.
By the way noticed that with the AC on the volts dropped from what I think would be about 16volts to 12-13 volts. Could this a potential problem?
It's wonderful to have so much information available on the forum not to mention the immediate advice from forum members.
Thank you.
To 91 L98 engine stopped
