Red Line Shockproof Gear Oil
Old Jun 29, 2009 | 05:52 PM
Nihilum's Avatar
Nihilum
Cruising
Default Red Line Shockproof Gear Oil
Hello everyone,
I have an 89 corvette with the ZF 6 speed that is making a nasty sound from the bell housing underneath. The sound is like rocks in a can or the sound of a diesel truck running. Has anyone had any success at eliminating a sound like this by means of a different type of gear oil. I am currently using 10w60 synthetic oil in it. I have heard someone recommend Red Line Shockproof. Does anyone have any success stories with this brand? If you did not use that brand, what did you use?
Thanks!
Joshua
Old Jun 29, 2009 | 06:27 PM
STL94LT1's Avatar
STL94LT1
I recently switched from Castrol 10W60 to Red Line Lightweight Shockproof. The trans seems a little quieter. But, I doubt it will make a big difference with your noise. I would try to find the source of the noise.
