Adjustable FPR, can't get below 46psi. WHY???
Old Jul 1, 2009 | 03:10 AM
powerpigz-51's Avatar
powerpigz-51
I have a BBK regulator that uses a new cap, disc washer and the stock diaphram and spring. When I was putting everything together, I noticed that my bolt was too long and hitting on the plenum. I left the disc out, which allowed me to screw the bolt in farther so it would not hit the plenum. The bolt would just contact the metal cap on top of the stock spring. I thought this would work, as I did not know the purpose of the disc (and still don't). My fuel pressure was very erratic, fluctuating very rapidly up to 10 pounds at idle, making it very hard to set accurately. It would also adjust itself over time, and was very sensitive to adjustments of the bolt. My engine seemed to run fine, but this always bothered me. So I took the plenum off, installed the disc and shortened the bolt by half. Now my pressure holds steady and is less sensitive to the bolt adjustments and stays in one place. My instructions say that with the disc in, and the bolt just touching, it should be close to stock. If you need to lower the pressure, you can gasket shim the cap, cut the spring, or use a thinner disc, as mine was pretty thick. One cut out of some thin sheet metal might work. But you do need the disc in there.
Old Jul 1, 2009 | 10:45 AM
jackdk's Avatar
jackdk
Originally Posted by ch@0s
Maybe? that's a question for Jon... Jon u out there?
Is your engine stock? what size injectors?
You Could also have a vacuum leak causing you to run rich, not uncommon with TPI.
Maybe I will get Jon in on this one. Maybe he has some suggestion.
Old Jul 1, 2009 | 11:51 AM
ch@0s's Avatar
ch@0s
I don't think our diaphragms are the same. The spring on mine is built in so it can not be cut. You should have used a longer bolt. The guys on thirdgen have been making their own AFR by drilling a hole in the regulator and welding a nut to the top so they can use a screw (no Disk). They have had no trouble with fuel pressure fluctuating. I do see how using a gasket shim would work, that is not a bad idea.
Old Jul 1, 2009 | 11:53 AM
conv90's Avatar
conv90
I have the exactly opposite problem with a Holley Adjustable Fuel Regulator.
With a 48.5 psi pressure I changed my exhaust to a true dual free flow one. At the track With the wide band connected I noticed that the new exhaust made the Air fuel ratio too lean.
So I tried to raise the pressure. With my surprise I had no more room turning the AFPR wheel clockwise...
I continued all the day doing 1/4 miles with WOT AFR of 13.7 13.9 values..
-Beppe-
Old Jul 1, 2009 | 03:03 PM
ch@0s's Avatar
ch@0s
-Beppe-
I can find the washer I tossed and send it to ya or u can put a nickle in it to bump up the pressure.
Old Jul 1, 2009 | 10:29 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by jackdk
The one I have is from TPI Parts, www.tpiparts.net part #FUL-200. It does not include, or call for any springs. I sent them an email to see why I can get below 46 psi. Still waiting for a reply. I will check out the one you have.
Thanks,
IMO, your problem was correctly diagnosed in this thread but you did not recognize the answer.
If the TPI AFPR is the SAME height as the stock bell, then it's the disk you installed that's causing the problem***. With the stock FPR, the bell/top put's pressure on the spring. (IOW, just installing a stock "bell" puts pressure on the spring. I just tried it.) And, as you should know, tightening the spring creates more pressure. By inserting the width of a disc, you compressed (tightened the spring) further. That's why your default (and minimum) pressure is higher than before.
The only way to lower your pressure will be to disassemble the unit and try again. (I doubt you'll be able to accomplish that w/o removing the plenum).
After disassembly, either toss the disc and buy a longer screw -- or purchase another AFPR that comes complete with spring/diaphram. If you choose the disc/screw method, expect the pressure to drop 2-3PSI (per the poster who suggested it). IOW, you should be back to stock pressure.
Gregg
BTW: I figured this out becaused I called TPI_Parts today and asked how the AFPR works. And, I should thank you for posting this because I might have done the same thing.
*** Footnote: This is the one question I did not ask TPIParts. However, based on your symptoms, I strongly suspect they're the same height.
Old Jul 1, 2009 | 10:40 PM
GREGGPENN's Avatar
GREGGPENN
.....I did not know the purpose of the disc (and still don't).....
My guess is the AFPR's are designed to work with units where a screw might fall off of -- or penetrate -- the spring assembly. More specfically, it's inserted to make insure the pressure chamber remains uniform for input/output. Non-uniform pressure on the spring could tilt the base -- creating erratic results.
However, considering how the top of the spring is constructed, it's seems reasonable to assume the disc may not be necessary with this style of stock regulator.
......If you need to lower the pressure, you can gasket shim the cap, cut the spring, or use a thinner disc, as mine was pretty thick. One cut out of some thin sheet metal might work. But you do need the disc in there.
Shimming the installation is another good idea I didn't think of during my prior post above. Choice of shim/gasket material would obviously be of utmost importance to avoid fuel leeching.
Old Jul 1, 2009 | 11:10 PM
ch@0s's Avatar
ch@0s
I also like the shimming idea.You could use the ring that fits over the stock regulator.You would need to use a shorter screw or it will hit the intake and bump the pressure up. The reason I didn't do it is because I wanted to have room to work with.
Old Jul 1, 2009 | 11:29 PM
GREGGPENN's Avatar
GREGGPENN
Not a bad idea. Just realize that ring has a rolled edge. I think it would require removal or a gasket to make it work.
Old Jul 2, 2009 | 12:44 AM
ch@0s's Avatar
ch@0s
I don't have one handy but as long as the bottom is flat it will work. Use the ring as a spacer between the regulator and hat. If its not flat take some sandpaper on a flat surface and make it flat.
Old Jul 2, 2009 | 01:30 AM
GREGGPENN's Avatar
GREGGPENN
Flatness (consistency of thickness) is key. Otherwise you could leak fuel. I'd put money on that ring being added just to make sure pressure is even around the ring.
Old Jul 2, 2009 | 11:33 AM
jackdk's Avatar
jackdk
I think there are some misunderstanding what I'm trying to say. If I turn the adjustment screw in, you can feel the screw is against the disc, and the more I turn it in, the higher the pressure goes. But when I back the screw out, I will get to 46 psi, (the lowest psi I can get)then the screw goes limp, and you can tell it is no longer making contact with the diaphragm. I need to get it down to at least 43 psi. I an getting 46 psi w/vac line off, and 36 psi w/vac line on. A five minute test has me smelling like exhaust, so it is without a doubt running rich.
There are some saying put a longer screw in, or shims, thats not going to do it, that will just increase the pressure...
Old Jul 2, 2009 | 12:03 PM
  #33
GREGGPENN's Avatar
GREGGPENN
You aren't getting it. Maybe you don't remember how the spring top is shaped inside the unit? It's got a significant depression in the middle.
The use of a longer screw is ONLY suggested if you REMOVE the thin disk that came with your AFPR. The longer screw is suggested to reach into the depression without losing screw length above the hat.
Shims mentioned are to be placed between the top and bottom halves of the regulator. They'd raise the hat and lower the pressure against the internal spring.
Think about it until you get it.
Edit: If you still don't understand, answer one question. Did you install the thin disk with your TPI_Parts AFPR? If the answer is yes, ask yourself what would have happened if you'd put it under the original "hat" of the OEM regulator.
Old Jul 2, 2009 | 03:38 PM
  #34
scotth48's Avatar
scotth48
I have an opposite problem with only 34-35psi. Put in new pump and regulator. Also have new bosch 3's that Jon sent me as the previous owner had gotten the wrong ones for my
'93. If pressure would stay at 35 along with the volume it would be ok. I just don't like it when it spits and sputters when in dropped below 20. I also put a new filter in. I was also getting code 44 and 64 lean os2 even on the new ones I installed. Of course my goal has been fuel economy, so maybe the 35 will work.
Old Jul 2, 2009 | 04:02 PM
  #35
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
you need less tension against the diaphragm. the shims raise or lower the pressure depending on the thickness of the shim by extending the space inside the reg that the spring takes up. but if you have none then the spring pressure on the diaphragm is to much. When you apply vac to the can the diaphragm pushes less downward releasing pressure. Forget that its adjustable. The way its put together it is a 46lb regulator non adjustable. you have to get the hat farther away from the diaphragm, so you insert a shim between the hat and base. about 15,000 of an inch reduces pressure by 5psi. now you can use the adjusting screw to preload the spring and get to 43.. even 40 might work in your case.
Old Jul 2, 2009 | 07:07 PM
  #36
powerpigz-51
This makes sense Gregg, that the pressure is distributed around the outer edge of the spring, as it is with the stock cap on it. Maybe the material capping the spring is too flimsy to have all that pressure concentrated in a pinpoint spot or it is affected by heat. The point I was trying to make in my post is that if you use the stock diaphram, the use of the disc washer is neccessary, as it was in my case. My bolt was certainly long enough to touch the spring cap. I can see how cutting the spring is probably out of the question.(as Chaos had pointed out). I think a thinner slug could be used succesfully to lower the base pressure. I am also wondering if the stock cap could be pounded out using a large socket as a punch, and a welded nut, disc and bolt? In the OP's case....a hat shim is probably the best bet.
