Headlight question
Old Jun 30, 2009 | 10:32 PM
josephf31's Avatar
josephf31
Default Headlight question
Is there a way to get the headlights to stay in the up position but have
the headlight switch turn them on/off? Thanks!
91 Coupe
Old Jun 30, 2009 | 11:01 PM
Mark85Vett's Avatar
Mark85Vett
You could unplug the motors and use the ***** to crank them up manually...but if the gears inside are stripped, you're SOL.
Old Jun 30, 2009 | 11:22 PM
josephf31's Avatar
josephf31
Default The
gears aren't stripped, I'm able to get the lights up and down with the switch but I am pretty sure I have an electrical drain from the motors,so I want to be able to leave the lights up but use the switch...possible?
Old Jul 1, 2009 | 06:44 AM
floridamale's Avatar
floridamale
Yes
As stated unplug motors roll lights up manualy use headlight switch to turn lights on & off
Old Jul 1, 2009 | 06:46 AM
floridamale
Yes
As stated unplug motors roll lights up manualy use headlight switch to turn lights on & off. They will stay in up position untill your roll them back down or reconnect motor.
Old Jul 1, 2009 | 11:38 AM
josephf31's Avatar
josephf31
Default More than one connector?
Originally Posted by floridamale
Yes
I rolled up the lights, disconnected the electrical connector that has 4 wires, if I disconnect it then the motors don't work but neither does the switch; is there another connector for JUST the motors, not the 4 wire one right under the headlights? Thanks!
Old Jul 1, 2009 | 12:08 PM
Mark85Vett's Avatar
Mark85Vett
follow the harness right from the motors...its a weatherpack plug, I think its grey
Old Jul 1, 2009 | 12:17 PM
aminnich's Avatar
aminnich
You have to disable the H/L module in the LF wheel well. It controls only the motors so the lights will still work. Why are you doing this??
Old Jul 1, 2009 | 01:15 PM
floridamale
Not the light conector follow the wires off the motor
Old Jul 1, 2009 | 01:35 PM
jimg's'93's Avatar
jimg's'93
Before you disconnect the motors, why not test them for what you suspect is a drain?
Read JFB's post on this thread (Last post):
http://forums.corvetteforum.com/c4-g...ery-drain.html
Connect your VOM up as described and take a read. Then disconnect your headlights and take another read to see if it's actually as you suspect. If not, keep on going, pulling fuses until you find the culprit.
Old Jul 1, 2009 | 01:45 PM
josephf31's Avatar
josephf31
Default I
am trying to pinpoint the cause of a slow battery drain, and I suspect one or both of the headlight motors at this point. If I can isolate and disconnect the motor circuit it will help me achieve that goal.
Do both motors run off the same circuit/connector?
Thanks!
Old Jul 1, 2009 | 03:03 PM
aminnich's Avatar
aminnich
Thanks!
Like I said, find the module and disconnect the wires (pull the plug in other words). But why not do a simple current draw test?
Old Jul 1, 2009 | 03:12 PM
floridamale
Each motor has there own relay its located drivers side front well in a box
Old Jul 1, 2009 | 08:05 PM
josephf31's Avatar
josephf31
Default I
think I found them, thanks!!!
To Headlight question
