AIR pump?
Old Feb 11, 2002 | 09:12 PM
BAdAzZV8's Avatar
BAdAzZV8
Default AIR pump?
Is that the thing that is under the driver's side headlight(in the little pocket, by the horn)?
I am going to get rid of my EGR, and I was just assuming that the AIR pump was the thing that had a tube running from the EGR to it.
Old Feb 12, 2002 | 03:27 AM
dtorc4's Avatar
dtorc4
Default Re: AIR pump? (BAdAzZV8)
Nope. The AIR pump is belt driven. It is on the drivers side above the Power steering pump, on the very top. It is quite large. :cheers:
Old Feb 12, 2002 | 03:54 AM
GlockLT4's Avatar
GlockLT4
Default Re: AIR pump? (dtorc4)
:confused: :confused: :confused: :confused: Not on mine it's not. But it's definitely not belt driven. All that the belt drives is the damper, the power steering, the alt, and the A/C. (and the tensioner). No air pump there on mine!
I'm with you BadAzzV8. The motor under the headlight is a vacuum pump or air pump.
[Modified by Glock'94, 2:00 AM 2/12/2002]
Old Feb 12, 2002 | 07:34 AM
HTRK-1's Avatar
HTRK-1
Default Re: AIR pump? (Glock'94)
The air pump (hair dryer) on an LT1 is under the driver's headlamp and is electric not belt driven, saves load on the motor and I believe it pumps air to the catalytic converter for emissions. :cheers:
Old Feb 12, 2002 | 02:44 PM
BAdAzZV8's Avatar
BAdAzZV8
Thanks guys, just wanted to make sure I wasn't removing something important.
To AIR pump?
