Motor question
Old Jul 2, 2009 | 04:43 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Default Motor question
Did dry compression check on my 161k L98 engine. 3 cylinders were at 145 and the rest were 160-190. We put in new plugs and new injectors and the engine ran rough afterwards. One cylinder was not firing. I removed the plug and the ground was bent down to the center electrode
I ran the motor with the plug off for a few seconds to see if anything would blow out the plug hole. Didnt see anything so did another dry compression test and this cylinder dropped from 145 to 90.
I put in one of the old re-gapped plugs and the engine ran ok. Sounds like time for a new motor.
Any ideas on what would bend the plug?
Old Jul 5, 2009 | 05:12 PM
MotorCity_87_C4
I have about $5000 to put into a motor, what is the most cost effective? Pull the original engine and re-use as many parts as I can or get a crate motor and re-use the fuel injection parts (TPI)?
Old Jul 5, 2009 | 10:15 PM
JackDidley's Avatar
JackDidley
If you want stock, rebuild what you have. If you want more power, the options are huge. $5000 wil put together a nice motor.
To Motor question
