4+3 Shifter Assy Removal
Old Jul 2, 2009 | 06:46 PM
mcguirjf's Avatar
mcguirjf
Default 4+3 Shifter Assy Removal
Can you remove / replace the threaded shifter rod without removing the entire assy? I pulled the pin and I can only pull the shifter rod up about 1/2 an inch. Is there something else I have to disconnect? Does anyone have a expanded parts view of the shifer assy? I need to know if I have to buy the whole assy with linkages.
Appreciate the help
Old Jul 2, 2009 | 07:16 PM
rodj's Avatar
rodj
The shifter assembly is bolts to the side of the tunnel.
You should be able to disconnect the rods inside the car and take shifter out
This is a 4+3 shifter in a custom app but the rod connections are stock setup
http://www.corvette-guru.com/uploads...d457766f72.jpg
Old Jul 2, 2009 | 07:20 PM
pologreen1's Avatar
pologreen1
what year is your car? is the O/D button on the shifter?
so you have the **** off, but you want to take the whole shifter out?
Old Jul 2, 2009 | 09:01 PM
rodj's Avatar
rodj
Makes no difference if taking whole shifter out ; unplug the wires at base , disconnect linkages and undo the bolts holding shifter to tunnel
Old Jul 4, 2009 | 12:37 PM
mcguirjf's Avatar
mcguirjf
Great picture! Mine is an 87 with the button on the ****.
So I have to disconnect the linkages on bottom to remove the shifter. Here I was thinking removing the pin and it came straight out and easy!
To 4+3 Shifter Assy Removal
