when your doin 70 mph....
Old Feb 12, 2002 | 09:07 AM
miker61588's Avatar
miker61588
Default when your doin 70 mph....
trying to find out if someone had maybe changed the gears in my car, just wondering how many rpms are you doin around 70 mph and with what gears
Old Feb 12, 2002 | 09:17 AM
neekos's Avatar
neekos
Default Re: when your doin 70 mph.... (miker61588)
I have a 94 LT1. At 70 mph I am around 1500 RPM'S. I have 2.59 gears.
vader86's Avatar
vader86
2000rpm with 3.07s at 70mph
Old Feb 12, 2002 | 09:28 AM
DON M's Avatar
DON M
I do 2000rpm @ 70mph. I have the performance ratio and I'm supposed to have 2:73 gears.
The post above by vader86 gives the same info for 3:07. Whats up with that?
Old Feb 12, 2002 | 09:40 AM
tommelton's Avatar
tommelton
Default Re: when your doin 70 mph.... (DON M)
You also need to specify what transmission gear.
The best way is to match transmissions and gear selected. IE auto and 4th or auto and 3rd, or ...
To cross transmissions, you should use auto 3rd and manual 4th, as both are 1:1 ratio in those gears.
You also need to know it the tires are stock sized.
Now, that being said, my 86 with 3.07 auto in 4th gear is 2000 RPMs with stock sized tires.
Tom Melton
82 CE
86 Z51 Coupe
Old Feb 12, 2002 | 11:56 AM
BobMachus's Avatar
BobMachus
Default Re: when your doin 70 mph.... (tommelton)
Mine has 2.73's, and in OD (.70:1) I do 2000rpm at 70mph.
Old Feb 12, 2002 | 11:59 AM
dtorc4's Avatar
dtorc4
2000@70 w/ 2.73
Old Feb 12, 2002 | 12:04 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I have 3:73's w/ auto and stock size tires...at 75 mph I'm right at 2600 rpm...sorry I don't remember the 70 mph revs...
Old Feb 12, 2002 | 12:19 PM
scorp508's Avatar
scorp508
Default Re: when your doin 70 mph.... (golfboy1)
4+3 in 4th overdrive gear = 0.68:1, with my 3.07s that puts me at about 2000rpm for 70mph.
Old Feb 17, 2002 | 08:48 AM
miker61588's Avatar
miker61588
Default Re: when your doin 70 mph.... (scorp508)
thanks for the feed back
Old Feb 17, 2002 | 11:35 AM
HighHopes85's Avatar
HighHopes85
Posted this last night in a different thread...
I will get you started on this one so you can compute it for any size tire, RPM, gear ratio, or tranny ratio
MPH = (RPM * TD * pi) / (GR * TR * 1056)
where:
MPH-Miles per hour
RPM-Revolutions per minute
TD-Tire diameter in inches
pi-3.1415926...
GR-Rear gear ratio
TR-Tranny gear ratio (4th on a 6 speed is usu. 1:1)
1056-Constant that takes care of inch-mile and minute-hour conversions
For tire diameter, tires are rated like 255 50ZR16
where
255-(SW) sidewall width in millimeters
50- (AR) aspect ratio
16- (WD) wheel diameter in inches
TD = [([(SW) * (AR/100)] * 2)/25.4] + WD
So for your case,
RPM = (MPH * GR * TR * 1056) / (TD * pi)
What did [i]you[i] come up with?
With granny gears and locked TC, I am pushing about 1650 RPMs (.70 4th gear) and 255 50ZR16's. -Matt-
Old Feb 17, 2002 | 12:52 PM
Bat Man's Avatar
Bat Man
Default Re: when your doin 70 mph.... (HighHopes85)
This should be close enough (68mph)
Old Feb 18, 2002 | 12:32 AM
MrNuke's Avatar
MrNuke
Default Re: when your doin 70 mph.... (Old Sport)
2100rpm @ 70MPH.
Old Feb 18, 2002 | 08:46 AM
chucks88's Avatar
chucks88
Default Re: when your doin 70 mph.... (vader86)
Ditto :cheers:
Old Feb 18, 2002 | 12:18 PM
miker61588's Avatar
miker61588
i just ordered gears 3.75 from jegs
Old Feb 18, 2002 | 01:03 PM
GlockLT4's Avatar
GlockLT4
Ditto: 3.07's.
Old Feb 18, 2002 | 11:28 PM
Shark ssn591's Avatar
Shark ssn591
my '88 3.07 rear, 700R4 auto 2000 rpm
email me if you want a "windows" program that lets you specify, tranny, gear, rear end & wheel size, correlates RPM to MPH. Includes all the Vette tranny's & let's you add others to the data base. program is about 2MB, let me know & I'll mail it :chevy
To when your doin 70 mph....
Old Feb 19, 2002 | 02:17 AM
OrangeC4's Avatar
OrangeC4
Stock gears in my vette, I am doing about 1700-1800 RPM's. I know for a fact I am doing 2000, at 80 MPH. That is what I cruise at.
Old Feb 19, 2002 | 03:05 PM
Cigarman's Avatar
Cigarman
My '89 vert has 3.54 gears (car built before 3/89--RPO is GH0) What does your have? and what is your current mph/rpm?
GH0 Rear Axle, 3.54 Ratio
GM1 Rear Axle, 2.59 Ratio
GU2 Rear Axle, 2.73 Ratio
GW4 Rear Axle, 3.31 Ratio
G44 Rear Axle, 3.07 Ratio
I can't check my mph/rpm today, I'll try tomorrow.
Also, nice to see someone else with a red '89 vert. What is the interior color? Factory options? Mine is as stock as yours is modified.
[Modified by Cigarman, 2:07 PM 2/19/2002]
Old Feb 19, 2002 | 09:57 PM
daves87's Avatar
daves87
At 70 mph im at 1800rpm with CT locked and 2.56 gears. AT tranny.
:chevy
