86 window regulator upgrade
Old Jul 6, 2009 | 01:43 AM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default 86 window regulator upgrade
I just bought some used updated regulators for a 1986 vette. Im having a REALLY hard time trying to adjust the windows!!!!!!!!!!! I have new weatherstripping and new outer door seals for both doors. Ive loosened all bolts and nuts and Im having no luck. Its either hitting the pillars or its bowing out near the top. Ive been messing with it for the last three days. Im going to burn this car! Does anyone have any pointers?
Old Jul 6, 2009 | 02:03 PM
Chapindad's Avatar
Chapindad
What is the problem? Is the door having a hard time shutting?
Old Jul 6, 2009 | 02:08 PM
jhammons01's Avatar
jhammons01
At the Bottom, did you have to drill the holes for the bottom mount of the scissors type regulator??
If so, I'd start there. The New OEM ones from thepartsladi has a template that tells you just exactly where to drill.
Old Jul 6, 2009 | 07:26 PM
gbrtng's Avatar
gbrtng
There are two regulator types, the originals with the toothed belt that breaks, and a scissors type that are used on the newer C4s and is the only style serviced by GM now. Which ones are you installing?
To 86 window regulator upgrade
