87 Transmission Swap
Old Jul 6, 2009 | 10:37 AM
l98-87's Avatar
l98-87
8th Gear
Default 87 Transmission Swap
I have been toying around with the idea of switching my automatic '87 to a manual for awhile now and I have finally found a cheap 4+3 transmission that includes "shifter, linkage, slave cylinder, bell housing, clutch, pressure plate, flywheel, transmission, hydraulic line, and assorted hardware." all out of an '84. I could have the swap done at a shop but the mechanics said I might have to pay up to a couple thousand in parts and labor because of unknown factors in a swap. Or I could do the swap in my autotech class next year under the supervision of a professional mechanic. I would like to know who else has done this and what problems they encountered. Thanks.
Old Jul 6, 2009 | 10:50 AM
Mark85Vett's Avatar
Mark85Vett
do a search on this...you'd be much better off finding a decent car already equipped...but if you're adventurous, and don't mind hundreds of 'issues', have at it!!
Not trying to sound overly negative, but this is a HUGE undertaking, and it will be problematic from the get-go
Old Jul 6, 2009 | 11:29 AM
gbrtng's Avatar
gbrtng
Agreed - trade cars.
But if you must, get the factory service manual and see what's different between the manual and automatic. Probably the engine compartment wiring and the ECM at a minimum. And then there's the goofy rear end ratio in your automatic.
Old Jul 6, 2009 | 11:30 AM
c4cruiser's Avatar
c4cruiser
In addition to the parts, you will need the ECM from a manual tranny car of the same year if you want the 4+3 to operate just like it came from the factory.
While I like the 4+3 (have one in my 87 ), dealing with the electronics will be an issue. Besides hanging the clutch pedal and the related hydraulics, you might want to consider finding a used ZF 6-speed.
That way, you don't have to deal with the tranny cooler lines, the wiring, shifter mounting, and the ECM. The ZF has a .5:1 6th gear for cruising, a 5th gear for top speed and overall better gear ratios. It will be stronger than the 4+3 in terms of the OD unit.
IIRC, you will also need a different C-beam and driveshaft for the ZF.
Old Jul 6, 2009 | 05:45 PM
l98-87's Avatar
l98-87
8th Gear
Thank you all for your input and advice. the swap suddenly seems less worth it haha my vette has minimal mechanical problems now and I guess I shouldn't mess with it (and put a significant hole in my pocket doing so)
Old Jul 6, 2009 | 07:05 PM
mrbonzia's Avatar
mrbonzia
FIND A CAMARO with a t5 in it you ll have everything you need and there s a vendor on here that sell the bracket like 150.00 i bought a camaro off a guy and got eveything i need for the conversion i have 500.00 in the whole set up just waiting for the cold to roll in to do the change over
Old Jul 6, 2009 | 07:30 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
You will probably be better off without the 4+3 trans.
That said, understand that the car you have came with a 4+3 or an auto.
The problem arises with the 84 trans.
1. The 86 and up trans does not have a kickdown cable as the 84 does. The 84 is semi mechanical/electric, and needs throttle input to shift. You can even change the valve body from a later car to eliminate that part of the internal fluid routing.
I put one in a '57 Chevy truck, and the only real problem is where to put the engage button. I even installed an 87 power steering cooler with a remote oil filter to catch any debris. You can buy the cooler lines already made up at Autozone, and buy an inexpensive tubing bender to make them fit.
2. If you install the 84 trans in your car, you will not need an ecm, but a chip from a stick car . just plug and play. But it's not really necessary. You will have to use a jumper wire on the ECM to let it know you have a stick since there's no feedback to let it know the TCC just engaged.
3. if you use relays to engage the trans, you just need to manually engage the trans, and can leave the auto chip in place, just attach a disconnect switch on the brake and the clutch pedals.
4.I plugged the kickdown cable hole, and used a relay to arm the trans off of the ignition switch, and then used the output of that relay to engage the trans with a switch to turn it off and on. It is purely a manual selected trans.
Then I used a miniature K&N filter for the trans vents, and resealed the trans so it didn't leak.
You could do the same, and with the clutch or brake shut off switches, you just select the trans whenever you need the overdrive.
The only inconvenience will be you can't leave it in overdrive if it's wired that way.
I bypassed the clutch and brake switches because the trans wouldn't stay in overdrive unless I did.
So, I can go through the gears without the overdrive, or I can stay on the freeway at high speed, and shift between 3rd OD and 4th OD if traffic slows down, or I come to a steep hill around 60 mph. I can even leave it in 3rd OD, because it is 200 RPM lower than 4th standard.
anyway you slice it, you need to pay attention, and not fiddle with your phone, ipod, etc. or daydream. you need to pay attention and DRIVE the car. It ain't your moma's automatic anymore. It's a gearhead thing I guess.
Old Jul 6, 2009 | 07:39 PM
c4cruiser's Avatar
c4cruiser
The T5 from the early to late 8o's F-bodies just does not have the strength to handle the output from the Corvette L98. Those cars didn't have much over 200HP and most were rated at around 165HP.
For a daily driver, it may be fine, but bolt on a set of drag slicks, then the T5 will show it's weak side in fairly short order. IIRC, it's 3rd gear that usually goes first.
Old Jul 7, 2009 | 09:33 PM
joe wilson's Avatar
joe wilson
Been to the drag races lately? They've done wonders with automatics in the last few years. I have an 85 automatic and wouldn't consider changing to a manual now. You can do a lot of work to your automatic for what you can change over to a stick and the car will perform as well as or better than a stick and be more reliable.
Old Jul 7, 2009 | 10:24 PM
rodj's Avatar
rodj
rebuild and put a shift kit in it
use whatever C beam and D/S is in the car; need to swap yoke for ZF6 one
Old Oct 8, 2014 | 11:48 PM
jarjar1025's Avatar
jarjar1025
1st Gear
Would you still have to worry about all the computer stuff if you switch to a candidates intake?
To 87 Transmission Swap
