What are some things people have done to lower the hydrocarbin output to pass smog? I'm not running a stock tune, but I've adjusted the BLM to be almost exactly 127 in the ranges they are testing. CO2 and NOS are all in the green, but I still can't seem to pass. The car passed two years ago which was less than 5,000 miles in my case. I had to replace the plugs and the PCV valve at the time.
A little info on the mods:
I'm running a 170 thermostat and have the fans comming on to keep the temps low. MAF is descreaned and ported, K&N airfilter with a cut out air box. FIC Blue Demon 24LB Universal Balanced Fuel Injectors. Adjustable fuel pressure regulator.
Hydrocarbons are unburned gas, usually caused by a misfire. To fail at 15 and 25 mph, the miss should be noticable. How are all the tune up parts, cap, rotor, plugs, wires? How many miles on the engine, and injectors?
I just changed the plugs and PCV valve last night. Fuel injectors have less than 5000 miles on them. Engine has about 117K. Opti was replaced around 75K when the watter pump blew. The internals of the engine are stock, so no cam.
Thanks again for looking at this for me guys. I've got 5 more days to figure it out before my registration expires. So if I have time I may try a retest this weekend with my new plugs.
I would retard the timing to stock if you have added over the stock base timing and if it is stock now take out 3 degress and bet that sneeks you under the limit.. One question how old is the cat or cats and is the air pump all working.. getting it good and hot wouldn't hurt either.. as in normal as designed temps.
Edit
oops did not read carefully enough you have opti so no changing the timing unless with a chip burn from what I understand.. That leaves you with cats working air pump working and proper tune up.. what is the integrator llok like and are the o2 cross counts nice and fast or sluggish. Could be a lazy o2 letting it stry too far into the rich side or plugged dying from old age not seeing the proper o2 reading. When that happens they usually get slower as well.
Edit
The tune is not stock. I tinkered with it quite a bit a few years ago. But I don't remember adding timing at idle. O2 Sensors where replaced about a year ago and the readings a pretty quick. The cats are 3-4 years old. I am having trouble finding my stock tune. Which because I've installed the 170 thermostat and lowered my fan temperatures it does run a lot cooler at idle. That I suspect is contributing to my problem. Does anybody know where I might be able to purchase/download a stock tune?
Thanks.
Thanks.
Sometimes you have to do desperate things to pass smog ( I license my 91 out of county ) go to Home Depot and get some denatured alcohol with about 1/2 tank of gas pour it in the tank and make sure it is mixed up and go to smog then go immediately and fill the tank, this should get you a pass.
You know, I picked up a gallon the other day. Thinking this might be my last resort. I've got a test scheduled on Wed and my tank is pretty full right now. Do you think a gallon would do it mixed in with 16 gallons or so of 91 octane?
I did find my stock tune, but after thinking about it might not be the best idea. I've installed a larger MAF, which I re calibrated the computer for. If I put the stock tune back in I'll have a few hours of driving and data logging to get the stock tune working well with the new MAF.
Well, I failed again. I had the guy diagnose the problem this time and he said my cats aren't working. They only about 4 years old, but he said after market cats don't last very long and that's probably why they failed. Then he drops the bomb on me. The cat on the passenger side is discontinued and there are no more OEM versions in the entire country! And they just changed the rules in California and they are not allowed to install after market ones any more. Only OEM, of which there are no more. So it sounds like I'm about to loose my baby.
Or, I need to find an unscrupulous muffler shop that will install aftermarket cats so I can pass SMOG, then I'll probably be right back here in two more years.
Time to either learn to wrench or pay a friend to do it for you and install aftermarket cats and get it done they have no idea when the cats were changed..Last week last month last year.. Just go to a different test station... I am sure you can find them cheaper than this but a start..
