C4 ASR service
Old Jul 8, 2009 | 03:25 PM
alx's Avatar
alx
Default C4 ASR service
Hi . My car is 1992 Lt-1 auto . The problem is that while driving the light ASR service can light . No changes in driving exept not working ASR. But if I stop the engine - it wil not start. Injectors are not working at this moment . If I switch ignition on & this light is on - engine not starting. If I switch ignition on and light is gone - engine is working... While driving it will not stop.Only after stop it will not start... Can somebody help me???
Old Jul 8, 2009 | 05:57 PM
94z07fx3's Avatar
94z07fx3
It sounds like a short somewhere and it won't be fun to chase down. Next time you have the light on no start pull the ASR/ABS fuse and see if it starts.
Visually inspect the ASR/ABS compartment behind the driver seat for signs of water/corrosion/evil gnomes etc
Old Jul 9, 2009 | 08:57 AM
alx's Avatar
alx
I pulled it ,light gone ,but no start again.
Old Jul 9, 2009 | 02:38 PM
alx's Avatar
alx
up !
Old Jul 9, 2009 | 02:44 PM
reoch999's Avatar
reoch999
Does the service engine light ever light up? I'm wondering if maybe it's burned out or something and supposed to be on at the same time as the ASR light.
Either way, have you tried pulling the codes? It's pretty simple to do and it may point you in the right direction.
Old Jul 9, 2009 | 03:18 PM
alx's Avatar
alx
Check engine light is working properly... I checked engine codes. When engine is not starting ,it tell me - no fault codes !!!! I checked it by connecting A& B. I didnt check ABS or ASR codes...Tomorrow I ll try...
Old Jul 9, 2009 | 04:21 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Did you check the amount of brake fluid in the resevior???
Old Jul 10, 2009 | 02:36 AM
alx's Avatar
alx
I checked it , cleaned the glass ,checked tire pressure !!! I asked about help !! Dont ask stupid questions . I thought that serious people are here ????? Am I right ??? Here is tech help or what ????
Old Jul 10, 2009 | 03:22 PM
alx's Avatar
alx
Old Jul 11, 2009 | 02:51 AM
LT4 F45's Avatar
LT4 F45
it is not a stupid question low brake fluid will get the SERVICE ASR light on... we just try to help you...
Old Jul 11, 2009 | 01:19 PM
alx's Avatar
alx
There is one more thing .When engine is not started SYS is blinking on the dash .What does it meen? I couldnt find it anywere...
Old Jul 11, 2009 | 03:41 PM
alx's Avatar
alx
Engine not start !!!!!! Brake fluid??!!
Old Jul 11, 2009 | 03:49 PM
LT4 F45's Avatar
LT4 F45
BRING IT TO THE GARAGE AND SHOW THEM HOW TO FIX IT.........
Old Jul 11, 2009 | 04:11 PM
TravisD's Avatar
TravisD
Have you pulled the codes from all the modules yet?
Old Jul 12, 2009 | 10:37 AM
alx's Avatar
alx
1 - h41
9 - h72
Old Jul 12, 2009 | 05:24 PM
L71Maynard's Avatar
L71Maynard
I had the same problem in my '92. I found a loose ground by my oil filter on the side of the block. I also found that my ECM was not working correctly. Sounds like your ECM is dying a slow death.
Dave
To C4 ASR service
