Trans leak solved but EXPENSIVE?
Old Jul 8, 2009 | 05:29 PM
rjhcorvette's Avatar
rjhcorvette
Default Trans leak solved but EXPENSIVE?
Hey everyone, I posted a thread last week about my '93 lt1 leaking trans fluid. I took it to a shop and they called me after dropping the trans that the pump and the torque converter were shot, thus pushing out the front seal causing the leak. They quoted me at around $1400 to replace those parts, put new seals on the front and rear of the trans, and for labor to drop/install the trans overall. I am just wondering if anyone else had these repairs done and what they paid. Am I getting ripped off or does this sound reasonable? Thanks.
Old Jul 8, 2009 | 05:34 PM
94z07fx3's Avatar
94z07fx3
I think some have had rebuilds done with upgraded parts to cover the known weaknesses of the 700R4/4L60/4L60e by pros for $2,200 - $2,600. I'm not saying you got ripped off I'm just saying $1,400 is a substantial portion of a total rebuild.
Old Jul 8, 2009 | 07:21 PM
Corvette Chris's Avatar
Corvette Chris
Thats more than I paid for my 700R4 rebuild. I'd say the price was a bit high.
Old Jul 8, 2009 | 07:34 PM
pologreen1's Avatar
pologreen1
agree /\
Old Jul 8, 2009 | 07:41 PM
mako41's Avatar
mako41
I had my 700R4 rebuilt by pros, using upgraded performance parts, for $1200.00. It was out of the car in a shipping crate though, so no R/R costs.
Sounds a little high to me!
Old Jul 8, 2009 | 07:53 PM
jhammons01's Avatar
jhammons01
Just seems a bit high for a chevy transmission.
Did they put the 700R4 in the 93? (I'm asking because I really don't' know. )
Old Jul 9, 2009 | 02:50 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
my 23 year old 86 with 146,000 miles had a trans leak, and I replaced the pan gasket and because I was there, I changed the filter. $55 for synthetic fluid and 2 quarts of B&M trickshift and a filter with gasket.
on Tuesday...........pan is still dry
Old Jul 9, 2009 | 03:03 AM
cv67's Avatar
cv67
St. Jude Donor '05
I was quoted $600 to have a 700r pulled and the same repair done on mine, same problem as you. Laborwise mine is a snap compared to a Vette (its a van, nothing in the way) ...maybe his quote was a bit high but it defintely a pain to drop the tranny in a C4. There are other parts aside from the seal that need to be replaced, also. PeteK can fill you in more.
Old Jul 9, 2009 | 07:03 AM
Pete K's Avatar
Pete K
They are screwing you.
They should be ashamed of themselves.
Stock replacement converters are worth $75-$200
The rubber and metal seals are worth $40
Fluid is worth $40
Filter is $20
Bushing for front pump is $10
Locktite, brake clean, carb cleaners etc are worth $20
That is a maximum retail (for parts) price of $205-$330
Labor to remove and replace the trans is approx 4 hours
Labor to remove pump, and completely overhaul is 1.5 hours max.
While they are in the pump, they may want to add hardened rings, and new pump vanes (complete upgraded overhaul)
This is zero additional labor, and a maximum of $20 more in upgrades.
Sounds to me like their labor rates are worth approx $180 per hour.
I am in the wrong business.
To Trans leak solved but EXPENSIVE?
