HotCam Advance Timing
Old Feb 12, 2002 | 05:52 PM
tdock's Avatar
tdock
Default HotCam Advance Timing
Should the LT4 HotCam be installed with any advance (mechanical) or installed straight like the stock cam for an LT4? A friend/mechanic is going to help me install it and asked, so I thought I'd run it by the forum first.
Also does anyone have the grind specs for the LT4 HotCam?
Old Feb 12, 2002 | 06:13 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: HotCam Advance Timing (tdock)
I just installed mine straight in line with the old cam.
The specs are 218/228 .525/.525 112
GlockLT4's Avatar
GlockLT4
Default Re: HotCam Advance Timing (Nathan Plemons)
Same here .. just install it in line and do your adjusting via the computer.
Old Feb 12, 2002 | 06:16 PM
ChrisB's Avatar
ChrisB
I wouldn't put any mechanical advance or retard on a LTx based motor - at least on a 95+ opti style. The timing reference for the opti-spark is taken off of the dowel pin - if you advance or retard this then you are also advancing and retarding you timing, as well as changing your injector phasing.
To HotCam Advance Timing
