stupid spark plug question
Old Jul 9, 2009 | 01:20 PM
MP6's Avatar
MP6
Default stupid spark plug question
ok. so i bought NGK TR55s for my 92 lt1. however i do not think they are the iridium plugs. Does this matter in the sense that it will cause damage to my engine or are the standard TR55s ok to run?
thanks
Old Jul 9, 2009 | 01:47 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The NGK TR-55 Platinum plugs are more than adequate for a stock engine. If they don't say "Iridium" on the box (and you didn't pay upwards of $15 apiece for them, they are not iridium plugs.
Old Jul 9, 2009 | 04:58 PM
Strick's Avatar
Strick
My Iridiums where $7 a piece. From AutoZone, but not listed for Corvettes. The non iridiums will work just fine in your engine. They may not last as long. But we're talking 50K on your plug vs 100K on the Iridiums. Maybe.
Old Jul 10, 2009 | 12:57 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
thanks
They are not iridium -- as the iridium version's part number is: TR55ix.
However, the TR55's are also NOT platinum either (i.e. OEM) as their OEM version platinum plugs are part number is: PZTR5A-15.
Meaning you'll need to change them every 6-12k miles.
Hence the reason I put the TR55ix in our 94 and would recommend the same for you (as GM's service bulletin for our 2000 transam now recommends using iridium instead of platinum's, albeit acdelco, but acdelco doesn't make iridium for our LT1 engines).
btw, here's a link to the NGK website, use the 'part finder' pull down to find the above info for your 92: http://www.ngksparkplugs.com
Old Jul 10, 2009 | 02:02 PM
pianoguy's Avatar
pianoguy
I'm running the TR55 copper plugs ($2/each) - I don't mind changing them, pretty easy now.
To stupid spark plug question
