Ticking noise
Old Feb 12, 2002 | 07:10 PM
92BAV's Avatar
92BAV
Default Ticking noise
Hi all,
My LT1 makes a ticking noise when the engine is cold and I give it mild throttle. Any ideas what could be causing this? Could it be pre-detonation? I'm running 92 Oct. Also, I don't know if this is related, but sometimes under WOT the engine will hesitate a second, at around 4300 RPM. Thoughts?
TIA
Old Feb 12, 2002 | 08:25 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Ticking noise (92BAV)
Check your oil!!!
Old Feb 12, 2002 | 09:10 PM
vader86's Avatar
vader86
Default Re: Ticking noise (BAdAzZV8)
change the oil and put a bottle of Techron in
Old Feb 13, 2002 | 02:44 AM
GlockLT4's Avatar
GlockLT4
Yup, change that oil and put some Chevron Techron in there.... and hope it goes away :yesnod: :yesnod: . if it doesn't you may have a noisey lifter or something... maybe a rocker as well.
Old Feb 13, 2002 | 07:12 PM
92BAV's Avatar
92BAV
Check your oil!!!
It's definately not the oil. I just changed it and put in Mobil1.
-Sheppe
Old Feb 13, 2002 | 07:13 PM
92BAV's Avatar
92BAV
Default Re: Ticking noise (Glock'94)
I'll put in the Techron. If it's a noisy lifter, should I consider doing some head work? Can it cause damage if left alone? It only happens when it's cold (which is the weird thing).
-Sheppe
Old Feb 13, 2002 | 07:19 PM
92BAV's Avatar
92BAV
Haha, maybe I'll hop on over to this thread. ;)
-Sheppe
Old Feb 13, 2002 | 09:14 PM
KYVette90's Avatar
KYVette90
The miss could be a bad spark plug wire, rotor or cap.
Old Feb 13, 2002 | 10:29 PM
dizwiz24's Avatar
dizwiz24
The miss around 4300 RPM sounds like a bad opti. Thats what happened to me. But I temporarily solved it (don't know how) by replacing the plugs and wires with NGK TR55 Iridium's and MSD 8.5mm wires.
later on during a cam install I discovered the opti inards were rusted, bushing/bearing? non-existent, and basically in needs of replacing at only 30,000 miles
Old Feb 14, 2002 | 02:36 AM
GlockLT4's Avatar
GlockLT4
Default Re: Ticking noise (dizwiz24)
:eek: :eek: 30k .. that one bit it quick :(
Old Feb 14, 2002 | 06:13 PM
92BAV's Avatar
92BAV
Default Re: Ticking noise (KYVette90)
Thanks for that info - I'll be replacing those once warmer weather hits. :)
Old Feb 14, 2002 | 10:26 PM
93aquaConvert's Avatar
93aquaConvert
Well ive had my vette since it had 10k on it and everytime its cold i get a ticking , knocking, until it warms up.. I dont really drive it much when its cold but when i do i get the knocking :sad: Anyone know if a tune up would help this?
Old Feb 14, 2002 | 10:32 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
The ticking noise could also be the injectors. GM has a few service bulletins out about noise in the LT1 with the engine cold. I read some of them about the LT1 in the Impala. I'll see if I can hunt them back down again. It talked about knocks from the engine due to piston slap and wrist pin knocking also. Hope this helps and I'll try to find the service bulletins.
:seeya
Old Feb 16, 2002 | 01:42 AM
92BAV's Avatar
92BAV
Default Re: Ticking noise (96GrandSport)
:seeya
That would be really appreciated! :):)
-Sheppe
To Ticking noise
