Ok lets do it...383 please...
Old Feb 13, 2002 | 12:21 AM
Bat Man's Avatar
Bat Man
Default Ok lets do it...383 please...
Ok, I have 4k to spend.
What can I do with it?
383?
I'ma bit confused on what exactly makes the stroker.
Someone give me some direction here. :)
Old Feb 13, 2002 | 02:15 AM
dtorc4's Avatar
dtorc4
Default Re: Ok lets do it...383 please... (Old Sport)
A 383 stroker motor is made by installing a crank from a 400 block (3.75" strock) and putting it in a 350 block that is bored .030 over. :D :cheers:
Old Feb 13, 2002 | 02:32 AM
ChrisB's Avatar
ChrisB
Basically what is above - a 383 is a new crankshaft (3.75" stroke vs. stock 3.48") and a 4.03" bore (instead of stock 4.00"). This will at a minimum require new pistons, and new rods are normally used also.
When figuring your total cost don't forget to include labor on R&R of the motor (unless you can do it yourself) as well as other ancilliary items (custom programming, fuel system, etc.). Also don't ignore your heads/camshaft. A 383 with stock induction will not make much more power then stock - it will just do it at a lower rpm (with more torque).
Old Feb 13, 2002 | 03:06 AM
pablocruise's Avatar
pablocruise
Default Re: Ok lets do it...383 please... (ChrisB)
Save some money for a SuperRam too! Let that thing breath. What, got yer tax refund?
Old Feb 13, 2002 | 03:12 AM
GlockLT4's Avatar
GlockLT4
What kind of stroker you can make with $4k entirely depends on how much you can have the labor done for, and how much machine/porting work you want done. You can get an all forged rotating assembly for $1500-10,000 (or what ever you want to pay). Top end stuff will be a few hundred. Machine work can be anything from $500- again .. $10,000 + if ya want to.
I went with a cast crank and everything else forged. It and other parts together totalled around $1500. Machine work was around $600. Labor was $750 to R&R the engine, which is usually unheard of.
Old Feb 13, 2002 | 03:20 AM
NoWorries's Avatar
NoWorries
$4K should make a killer 350, but a not-so hot 383, not in an L98 anyways. The LT-1's are easier to program and more suited for the bigger cubes. A 350 is much more feasible unless you really want to get into spending money.
Old Feb 13, 2002 | 10:20 AM
dgoodhue's Avatar
dgoodhue
You can probably get a quality stroker 383 built (cast crank, forged rods, pistons which good to about 550hp) with the machine work $2500. If you paying somebody to the Removal and Replacement of the engine, putting on the heads, and the little small stuff, your going to eat up the rest of the money. If you can do the R&R work yourself, you can put some work into the heads, cam and porting the intake (if you have an L98)
BTW what year do you have? A MAF car ECM will respond better to the changes. Why do you want to do a stroker (is your engine worn out), a top end setup will net you more hp.
Old Feb 14, 2002 | 12:21 AM
Bat Man's Avatar
Bat Man
Default Re: Ok lets do it...383 please... (dgoodhue)
I would be paying someone to do the work for me.
And ya my car has 134k miles on it, and i want to add hp, but I feel the only safe way would be just to rebuild and build up.
I hear its not smart to add nos, or SC to a high milage engine.
So why not just do a rebuild and a build up?
Old Feb 14, 2002 | 12:22 AM
Bat Man's Avatar
Bat Man
PS: mines an 88
Old Feb 14, 2002 | 10:58 AM
jcazin's Avatar
jcazin
$4K is plenty of money- either do the ZZ4 350 or check out Speedo-Motive's site for short block 383's- chances are, your heads are fine.... just depends on how much of the work you want to do
Old Feb 14, 2002 | 11:10 AM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Well, here is what I have spent this year on my '88 to give you an idea.
383 short block-Scat cast crank, Eagle I beam rods, Speed Pro hypers, new oil pan, double roller timing set,dampener, and flywheel, all balanced, -$1,930
Heads-new in box, but used, Air Flow Research 190's-$1,200
Comp Magnum roller rockers, custom roller cam and lifters,pushrods-$700
Full Lingenfelter Super Ram, ported, used-$1,000
Lingenfelter billet throttle body, used -$300
Hooker Super Comp headers, coated, 2 1/2" dual exhaust-$1,000
Dana 44 with 3.07's used-$440
Spicer U-joints-$120
Raptor 2,600 stall converter, new in box, but used -$150
Belts, hoses, fluids, seals,plugs, cap and rotor, thermostat-$150
Nitto Drag radials and 17" Epsilon wheels,used -$250
Simpson Voyager Helmet-used $125
So, doing all the work myself and shopping wisely, I should have a pretty stout car for a little over $7,300. Unfortunately, this is what it costs to go fast with a durable,reliable, matched combination.:( A lot of people don't want to admit what they have spent on their cars but that is what I have spent, so far.........
Old Feb 14, 2002 | 12:26 PM
vader86's Avatar
vader86
Default Re: Ok lets do it...383 please... (Fastguy)
I would just buy the heads, accel 219, SR or MR, headers. Wait until you have more money to do a good rebuild job.
Old Feb 14, 2002 | 04:57 PM
Bat Man's Avatar
Bat Man
Well I have more then 4k, I just decided to set the cap at 4k.
Old Feb 14, 2002 | 04:58 PM
Bat Man's Avatar
Bat Man
Default Re: Ok lets do it...383 please... (NoWorries)
What do u suggest with the 350?
Old Feb 14, 2002 | 05:07 PM
Fastguy's Avatar
Fastguy
I would say intake,cam, exhaust. Look at L98 Terror's car. That has a 350 and has been in the 11's on drag radials.
Old Feb 14, 2002 | 05:14 PM
Bat Man's Avatar
Bat Man
Which intake?
Old Feb 14, 2002 | 05:15 PM
Bat Man's Avatar
Bat Man
PS I thought Terror had much more.
Old Feb 15, 2002 | 06:01 PM
Bat Man's Avatar
Bat Man
http://www.built4speed.com/html_docs...ked_to_383.htm
:eek: :eek:
Old Feb 16, 2002 | 12:18 PM
A's Avatar
A
WOW! :eek: Please someone point out the bad points about that motor!
Hey does anyone make a special 383 stroker crank that doesn't require the block modifications that a true 400 crank does?
Isn't it true that when you do a 350 to 383 you have to do some sort of grinding on the inside of the block due to clearance issues of the longer stroke? :confused:
What other sorts of gory details are involved in doing a 383?
[Modified by A, 11:31 PM 2/17/2002]
To Ok lets do it...383 please...
