Carbon in Plenum
Old Jul 12, 2009 | 01:01 AM
aklita's Avatar
aklita
Default Carbon in Plenum
Have an 85 runnung rough on idle and also when running. Going through the usual list checking everything, now down to the EGR valve. Just took my Plenum off and found alot of carbon deposit inside. Is this normal?
Tried getting the valve off but have given up too hard to get to the bolts off. I was going to check if there is any depsit in the valve.
Andy help would be apprceiated.
Andy
Perth WA
Old Jul 12, 2009 | 11:03 AM
Aardwolf's Avatar
Aardwolf
Yes it's normal for a lot of carbon to be in the intake. Any codes?
Old Jul 12, 2009 | 11:26 PM
aklita's Avatar
aklita
Default Re:Carbon
No codes
I've replaced all the iginition system coils, leads spark plug leads etc.
Now progressively going through checking EGR IAC timing etc.
Andy
Old Jul 12, 2009 | 11:30 PM
pologreen1's Avatar
pologreen1
the intakes get full of carbon
Old Jul 13, 2009 | 12:12 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I third the confirmation of carbon being normal for the plenum/runners. It is that EGR that controls exhaust being recirculated back thru your intake.
Have you checked your injectors?
Old Jul 13, 2009 | 12:38 AM
aklita's Avatar
aklita
Default Re:injectors
Might try checking the injectors while I have the plenum off
Andy
Old Jul 13, 2009 | 03:21 AM
samsonb's Avatar
samsonb
My 89 has a black coating inside the plenum as well. I took the IAT out to clean the gunk off of it. Would the black coating on the IAT affect its readings?
Old Jul 13, 2009 | 04:59 AM
aklita's Avatar
aklita
I guess the readings would unaffected as it seems normal to have carbon in the plenum!!
Old Jul 13, 2009 | 11:49 AM
redrose's Avatar
redrose
most have a coating of carbon caused by normal 'reversion', aggravated by 'retarded' cam timing to meet emissions mandates...excessive carbon build-up may be due to camshaft lobe/tappet wear, that wear will also produce rough idle and driveability probs...to check cam/lifters pull rocker covers and check lift at every rocker arm (one worn lobe will mess all)
Old Jul 13, 2009 | 03:03 PM
samsonb's Avatar
samsonb
Do you have a pic of what to look for? I'me putting my valve covers to paint them, so I figure this would be a good time to check that out.
To Carbon in Plenum
