Reasons to use a 6.0 rod in a 350
http://www.iskycams.com/techtips.php#2005
For street strip use , better things to spend your $$$ on.
i run a 5.7" 350 rod in my 400 personally. mainly since i feel it is a stronger/better rod plus the piston compression height is shorter and thus lighter. otherwise i wont spend any $ on a longer rod for anything...
6 inch rod reduces piston side load friction.reduces cyl wear.improves VE by delaying peak piston speed till later in the stroke,when the intake valve is opened further.
Received 3,043 Likes
St. Jude Donor '05
For most street builds 5.7 is fine but if youre going to twist it get the longest rod you can in there. Like them on strokers to in an effort to reduce sideloading and egg shaping the cyl.
Stock 400 rod is 5.56 (or 5.65?)
msd is set at 6400 on mine. seems pretty happy there too, even with a hyd flat tappet camp, comp XE284. usually shift at about 6200. need to get the th350 finished and get the first 11 under my belt...12.09 is just too close to let it stay
I started to write a reply to this yesterday as I worked a lot with it and did not like the way it read sounded.. Short story from my experience is it depends on RPM range intended use IE torquey street engine VS top end killer and cylinder head flow availability. Low end torque = shorter ratios 1.55 to 1.65 small heads and high rpm or max output race = 1.7 to 2.5.... It is all about peak airspeed in the port and mechanical advatage at the crankpin. A daily driver Vette for me would be 1.55 to 1.65 a race SBC 1.7 to 2.0 max a F1 engine and yes have tuned them too 2.4 to 2.8.. at 20k rpm..LOL... This is the mild version so ....
With proper parts choice longer rods can result in a reduced recipricating mass. (My 12.1:1 355 thrives on pump gas. The 6" rods from Scat weighed less than the stockers, the Mahle Power Pack pistons were lighter than the stockers too, and the machinist had to remove weight from crank IOT balance the rotating assembly "win, win, and win)
why not run a ZZ-383 cola crank and clearance the stock block a bit and then you can run production length rods and still get 383 cubes out of it?
My friend is building a 396 kind of like this but I believe using 6.00 carillo rods and this same crank & .030 over.
Road track motors benefit more that drag or street.
TJM
The biggest advantages of the longer rods is a longer dwell time at the top of he compression stroke, probably something like a 5 degree
improvement with the 6" rod over stock 5.7". This allows more pressure and that makes power.
The longer lever makes more torque.
So you get more "twist" and better combustion for "x" amount of fuel.
Pistons do become an issue, but one goes with the other
TJM
actually longer rods dont have any bearing on cubic inches.the 396 sbc and 383 sbc use different cranks.
the zz-383 uses 350 bore.
seeems to me stroke affects cubic inches ... right?
a longer rod does not move the piston any farther ie."increase stroke" beacuse the longer rod is connected to the piston in a different place.if you were to hook a 6inch rod to a piston made for a 5.7inch rod the piston would crash into head.basically the wrist pin on a 6inch rod is located closer to the piston face.
To be a little more clear a stock 350 is 4.000 x 3.48
A 377 Can either be a stock 350 block with a 3.75 stoke crank 4.000 x 3.75, or it can be a 400 block bored .030 over with a 3.48 stroke crank 4.155 x 3.48
A 383 Can be either a 350 block bored .030 over with a 3.75 stroke crank 4.030 x 3.75, or it can be a 400 block bored .060 over with a 3.48 stroke crank 4.185 x 3.48
A 385 is a 350 block bored .040 over with a 3.75 stroke crank 4.040 x 3.75
A 388 is a 350 block bored .060 over with a 3.75 stroke crank 4.060 x 3.75
A 396 (395) is a 350 bored .030 over with a 3.87 stroke crank and usually a 5.9 rod.
So if its a 350 block, and its in fact a 383 then the bore is 4.030.
