with an opti vacuum fitting/hose loose and water all over I predict disaster
I thought it did I saw an engine at a junkyard and the hose was facing down toward the opti but couldnt see where then when I grabbed it to see where it was going it came right off.
I tried seeing where the hose plugs into and you cant see s**t...on the bottom driver side is a vaccum hose and i grabbed it to see where it went and it broke!
