Radio help
Old Jul 12, 2009 | 09:17 PM
c23racing's Avatar
c23racing
Default Radio help
I am installing a regular radio in my 1990 vette. It has the bose in it with 3 of the amps blown. Can anyone tell me how I hook up the antenna to the new radio.
Thanks & God bless
Bill
Old Jul 12, 2009 | 09:41 PM
jfb's Avatar
jfb
The antenna will plug into the radio antenna socket, but I doubt that the radio has the switch contacts like the Bose did to run the antenna up when on and down when off, so you will need to jump the antenna motor wires to run the antenna up and leave it up.
Old Jul 12, 2009 | 09:46 PM
c23racing's Avatar
c23racing
Thanks but where is the lead plugged in? It did not plug in the old bose radio.
Old Jul 12, 2009 | 09:52 PM
jfb's Avatar
jfb
It sure did, but I believe (I have an 87) the 90 has a console on the dash with the tuning ***** etc. and the radio receiver located elsewhere. Follow the antenna coax to the radio! Maybe another 90 owner can tell us.
Old Jul 12, 2009 | 10:12 PM
c23racing's Avatar
c23racing
I found it under the kick panel. Thanks
Old Jul 13, 2009 | 05:30 AM
jeffp1167's Avatar
jeffp1167
if you are pulling your bose ... do you want to sell the CDM out of it?
Old Jul 13, 2009 | 10:16 PM
c23racing's Avatar
c23racing
I sent U a pm
Old Jul 14, 2009 | 12:02 AM
RLG's Avatar
RLG
you will need the antenna extension for your new radio. I just did this conversion on my 90. There are some other things you need to do to make it work with no problems. I don't know how much you know about the conversion so I don't want to assume you don't know
Old Jul 14, 2009 | 09:57 PM
c23racing's Avatar
c23racing
Thanks guys 4 all the info.
I put the ant. adapter on but it would not let the new radio go in far enough so I wraped some electrical tape on it and put a piece of duck tape across the back just for insurance. It picks up good I finished everything today & I am very proud of it.
Thanks again
Billy
Old Jul 15, 2009 | 07:22 PM
RLG's Avatar
RLG
Just curious , did you install the resistors for the data info?
Old Jul 15, 2009 | 08:58 PM
c23racing's Avatar
c23racing
Old Jul 15, 2009 | 10:49 PM
RLG's Avatar
RLG
Fandamtastic.
Most of the cars that had been converted, the back of the dash has been cut out to allow the depth of the new radio and the antenna to be installed. My 90 had already been set up for a aftermarket radio, so I was good to go.
To Radio help
