Engine misses at high RPM
Old Feb 13, 2002 | 07:58 AM
suzukrider's Avatar
suzukrider
5th Gear
Default Engine misses at high RPM
My 88 coupe is a little under the weather, when I get up to 70-75 MPH my car starts to miss (fishbite), I replaced the plugs, distr cap, ignition module, wires, rotor button and vacum line running to the EGR valve and its still doing it. I just had Chevy replace the intake manifold gasket and the clutch in Dec, so I was thinking that they could have disconnected something.Can some one please help me.
[Modified by suzukrider, 2:59 AM 2/15/2002]
Old Feb 13, 2002 | 10:45 AM
PonyH8R's Avatar
PonyH8R
Default Re: Engine misses at high RPM (suzukrider)
Mine does too so I would be interested what suggestions people come up with on this topic.
Old Feb 13, 2002 | 10:52 AM
flubuyu2's Avatar
flubuyu2
I have the Lt1 so I'm guessing here but since you've already done ignition maybe it's fuel starvation under high rev's???let me know very curious!
Old Feb 13, 2002 | 10:56 AM
Nathan Plemons's Avatar
Nathan Plemons
My old car developed a miss that NOBODY could track down. For those who have never experienced it, a miss on a 4-cyl is painful. I hope you get it worked out, I sold the car for it. Poor guys at the dealership didn't even test drive it :D
Old Feb 14, 2002 | 11:07 PM
suzukrider's Avatar
suzukrider
5th Gear
I was informed by Chevy that my engine was not missing, that at high RPM my car was going in and out of overdrive. As I think about it, it did fell as if it was downshifting at times and I did notice that the shift light came on once. I seen a articial in VETTE on how to by pass this function maybe I will try that. Thanks I hope this can help other Vette luvr's.
Old Feb 25, 2002 | 01:09 PM
PonyH8R's Avatar
PonyH8R
Hmmmm. Not sure that is the same with me then. Mine misses when I WOT it and continues until I let off. :confused:
Old Feb 25, 2002 | 05:48 PM
CORVETTE MIKE's Avatar
CORVETTE MIKE
When i had my 89 it did the same,it turned out to be catalytic converters gone bad.
Old Feb 25, 2002 | 06:05 PM
emoshn's Avatar
emoshn
Default Re: Engine misses at high RPM (CORVETTE MIKE)
Could also be valve spring tension. Weak valve springs will cause a high rpm miss. So will low fuel pressure. Check your pump pressure and you fuel pressure the the injectors. Could be a bad regulator.
Just as a thought. I had an all around poor running engine...wanted to stall at idle...wouldn't run up very well etc. Had a motorvac done on the engine. This cleans all things fuel...including valves/combustion chamber/plugs. Ran great afterwards...$100.
To Engine misses at high RPM
