Upgrading to LS1 PCM / ignition
Old Jul 13, 2009 | 04:29 PM
ScaryFast's Avatar
ScaryFast
Default Upgrading to LS1 PCM / ignition
What options are there to eliminate the LT1 ignition system (read: Optispark) and upgrade to an LS1 system?
I'm assuming I'll need:
LS1 computer
LS1 coils
Some way to get crank/cam position
New harness
What options are out there now to do this?
Old Jul 13, 2009 | 04:59 PM
STL94LT1's Avatar
STL94LT1
Default efi connection
http://www.eficonnection.com/24x/default.htm
Old Jul 14, 2009 | 12:13 AM
Mojave's Avatar
Mojave
There is only 1 game in town with any kit of kit for this, and he just linked it.
Old Jul 14, 2009 | 10:27 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Does anyone know if this will send the correct signals to the CCM so you don't have a check engine light and the gauges work correctly?
Old Jul 14, 2009 | 10:39 AM
ScaryFast's Avatar
ScaryFast
I've read the website over a few times and don't see any mention of that. I wonder if you still need your stock computer in there to run the guages, etc. Unfortunately, as is always the case with me, they're out of the office all week and I can't call for more info.
I don't need the guages myself, but I do want to know if I can completely remove the stock computer.
Mojave, what did you do about your ATI pulley? Did you have to pull your motor? I'm soooo frustrated that I didn't see this until we got mine back in the car. This would have been a no-brainer swap a few weeks ago when the whole damn motor was apart. Now it's a PITA to get in there...
Old Jul 14, 2009 | 12:07 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Are you still using the stock dash?
If so, you'll have to piggy back in the stock computer to run it.
Old Jul 14, 2009 | 01:54 PM
Ramrod92's Avatar
Ramrod92
Brian, I'm running a Dynaspark III rotorless opti, Delteq and a Accel DFI 7 with the stock CCM piggybacked (I think it's a Painless harness). I would like to see what anyone else is using to keep the stock gauges.
Old Jul 14, 2009 | 01:55 PM
ScaryFast's Avatar
ScaryFast
Nope. No stock dash here. I want a stand alone EFI system.
Old Jul 14, 2009 | 03:54 PM
DVNCI's Avatar
DVNCI
Originally Posted by STL94LT1
I might have done that before I bought my new Painless LT1 chassis harness but it was (and is) still pretty new and so unproven. Does anyone know someone who is using this?
This might be the route I eventually go since I'm not a fan of the LSX engine sound and this lets you keep the traditional firing order.
Old Jul 14, 2009 | 03:59 PM
BrianCunningham
I'd go aftermarket, say a FAST system.
You can run a conventional distributor, your just need someone to cut the hole for you.
EDIT
Or just plumb up a carb intake for EFI
Old Jul 15, 2009 | 10:17 AM
ScaryFast's Avatar
ScaryFast
EDIT
Yeah, but spending $1600 on an ignition system is counterproductive on this car, and anything other than a factory igntion will assess class points, regardless of my reasons to install. And while I can make the necessary modifications to the intake, etc, myself, it's hard to stomach going backwards with technology. Although going carb'd may be the best solution at the end of the day
To Upgrading to LS1 PCM / ignition
