Engine trouble
Old Jul 13, 2009 | 06:40 PM
arrested609's Avatar
arrested609
Default Engine trouble
I'm having trouble with my engine running bad after it gets hott. I have changed the fuel pump, vapor canister, fuel injectors, everything new in the distributor, I unplugged the Mass sensor with it running but it still ran bad. When it starts running bad it starts to over heat around 220 to 230. I have a new water pump, and just about every sensor on the engine has been changed. When it starts to run bad it's like is looses power and i have to keep the accelerator down to keep it running or it will just die out. When it does die out and i restart it it will pop inside of the intake like it's backfiring. Please help if you have any suggestions. Thanks, Craig. You can call me at (337) 263-4567 if you would like to. The vette is a 1988 L-98 350 Engine. I deleted the emissions and went with a Smog pump by-pass pulley. It ran good and started acting up about a month later.
Old Jul 13, 2009 | 08:03 PM
JAKE's Avatar
JAKE
Any SES light or codes?
Jake
West Point ROCKS!
