Zf6
Old Jul 14, 2009 | 07:04 AM
Ratsirt's Avatar
Ratsirt
Default Zf6
Just picked up a 92 with ZF6 tranny.
Putting the tranny into reverse takes some getting use to, is this normal?
You seem to have to fool with it to find the right spot.
New C4 owner.
Old Jul 14, 2009 | 07:25 AM
94z07fx3's Avatar
94z07fx3
If it is a 92 version of the tranny it should be just pulling up on the ring while pushing right of 6 and pulling backward. If it is a 96 version of the tranny (a PO could have dropped on into it) then you just have to push harder to the right and pull harder back. Either way it should be natural after a few times.
Old Jul 14, 2009 | 09:43 AM
-=Tom=-'s Avatar
-=Tom=-
The clutch fluid may be low.
Old Jul 14, 2009 | 10:29 AM
LD85's Avatar
LD85
or leaking at the firewall or at the slave,,,,
check the world famous ZF hydraulics
To Zf6
