what part number srp pistons did you 383 guys use in your lt1/lt4 vette
found good deal on some but want to make sure they are the right ones !!!!
thanx,guys !!!!!!!!!!!
If you can, spring for the longer rods.....you'll get more leverage on the crank (bottom-end torque) and you'll get less side load on the rings...that's why I went with 6.00" rods :D
I used Eagle SIR Rods, which are fine for your application :cheers:
already bought my crank and rods so i am stuck now !!! this is why i need the pn# for the correct srp's....i think they are #139628 !!!
anybody agree this is correct for my application ??
thanx,doug s.
:rolleyes:
Just looked it up on racenet.net I searched under your part no. 139628.
It looks fine with a 454 gram piston and same 10.4:1 compression ratio I have.
I will only add that because I have a longer stroke, the piston is shorter and thus weighs only 397 grams, which makes a big difference in rev response time.
But to answer your question, I believe this piston is fine for your application utilizing a 5.7" rod length.
BTW, what rings are you getting.....if I did it again, I'd go for the new Total Seal type rings to get a little extra bang for your buck. :D
I would probably stay away from a Total Seal/Gapless type rings. The theory sounds really good, but in real life they never seem to exhibit any benefit, and can quite often lead to problems.
Stick with a good plasma-moly ring (like C&A or Speed Pro) and you will be fine.
Quote:
"already bought my crank and rods so i am stuck now !!!"
Yeah but you are stuck with what I consider to be a better rod length for a street car.May be if it was a 6spd I would rethink "I don't know what trans you have" But even if it is ,not the end of the world.In the end the tune up will make the difference.
hey chris ??? is anyone having trouble with this combo ??
3.750 crank/5.700 rod ????? another question for you chris what cam would
you recommend ?? LT4 hotcam,lingen-219,or 306 comp/cam ????
:crazy: :crazy: :chevy :confused:
