My distributor has screw down type cap
i bought a clear "clamp down" mr gasket cap http://www.summitracing.com/parts/MRG-1263/
i couldn't use it,i can't use clamp down caps on my distributor
why ???? all of yours are the same ?
if i want to use it i have to change the distributor plate !!!!
Exactly,i managed to use the clear coil cap only
it shows my brute thunder but i wanted everything clear ...
im looking for some screw down clear cap with no luck
Try some redneck engineering & this is just a WAG on my part, If the spring locks are indexed to the cap in the same location as the screw down cap cut the "L" shaped bottom off the spring locks (a whiz wheel will do nicely, don't melt the cap) to remove them & replace them with screws.
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Good WAG! Yes this will work. Cut off the clamp ends, and replace with the old cap's screws. All the indexes are identical.
BTW I visited Valparasio, Chile many years ago.
The Communist newspapers were not very friendly. But the bars took our money just the same......
Yes i will let you know
I'd rather modify the cap than buy a new dist, but its not a bad idea !
Anyway for now...i did the clear coil cap only,so it shows my Accel Brute thunder
when i take the TPI Dist cover and i like it.-
I know this is a six year old thread but; I just did this and it works perfectly. I used 10x24x1 machine screws and they went right in with no problems. You could probably use a 3/4 inch screw also.
Just my experience.
Just my experience.
Necrothread !
Well, i wanted to install some clamp-on style distributor cap
i ended up using the screw style cap.
did you remove the clamps and installed those screws ?
i didn't get what you do, thanks anyway.
Necrothread !
Yes, you remove the clamps. You either cut or bend the bottom hooks. Then push up the springs and clamps. Then install your bought machine screws. The clamp down holes line up perfectly with screw down holes. It's a very easy conversion.
Hope this helps
