Ecm backup battery
Old Aug 27, 2015 | 07:37 AM
Christi@n's Avatar
Christi@n
Default Ecm backup battery
Disconnecting battery on 1995, how long can stay car without any trouble?
About ecm, has it a backup battery? No datas lost?
Old Aug 27, 2015 | 09:02 AM
WVZR-1's Avatar
WVZR-1
As long as you like. There's certainly after a long term removal a "relearn" effort for ECM but if you've an FSM it's an easy read. Clock and radio memory will be gone.
No back-up battery. Data loss? Yes, but easily recovered. What are you wanting to do?
Old Aug 27, 2015 | 09:04 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
No problems.
The tune programming will not be lost. The learned values (like long term fuel trims) will be lost, however the computer will relearn them in a few miles. I think it is a good idea to disconnect the battery periodically in order to lose the learned values. Mine was running good, but changed after a tank of maybe bad gas and mileage went down 4 or 5 mpg. I disconnected the battery then reconnected it and immediately it started running better and has been good since (over a year).
You may also lose the radio presets and time of day. To me that is not a big deal.
If you are still worried about it they make a small adapter that has a 9V battery that connects to the cigar lighter and is supposed to preserve settings while you disconnect the car's battery. I used one once, but it is almost more work than not using it.
Good luck.
Old Aug 27, 2015 | 09:12 AM
WVZR-1's Avatar
WVZR-1
I was afraid to mention that "it could be beneficial" but I thought someone might call BS
Now I just have to agree, a friend actually does this every spring when taking the car out of storage and his is on a Tender all winter.
Old Aug 27, 2015 | 09:22 AM
Christi@n's Avatar
Christi@n
Thank you guys
To Ecm backup battery
