Vibration-common suspects?
Old Aug 24, 2015 | 05:48 PM
DanielRicany's Avatar
DanielRicany
Default Vibration-common suspects?
Hello everyone. I have a vibration in the rear of my 85 Corvette. It seems most noticeable around 50-80 mph. I also notice that my wheel shimmys a little at those speeds.
What are the most common problems in regards to vibrations with these cars?
Thanks!
Old Aug 24, 2015 | 05:56 PM
crowz's Avatar
crowz
Bad tires.
Old Aug 24, 2015 | 07:55 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I agree, tires are the most common. Either bad or balance.
U-joints and/or half shaft u-joints can cause some vibrations too.
I have had bad tires and half shaft u-joint problems and both caused vibrations on mine.
Old Aug 25, 2015 | 10:02 AM
don hall's Avatar
don hall
https://www.tirerack.com/images/tires/vibechart.pdf
Old Aug 27, 2015 | 01:46 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
for me it was half shaft u joints and one bad rear wheel hub.
got under car, safely, and it was plain as day.
Old Aug 27, 2015 | 09:57 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Tires/wheels are the most common fault.
I would suggest finding a shop that uses a Hunter "Road force Touch" GPS 9700 machine to check them out. It will check balance, out of round tires/wheels etc. and advise the technician as to how to correct the problems.
To locate a shop try this link:
http://www.gsp9700.com/
After using a couple of shops to no avail, the Hunter did wonders for my 1990.
Old Aug 27, 2015 | 10:09 AM
VikingTrad3r
Oil Producer
if money and capital allocation are something the OP cares about, i suggest the op rule out the wheel hubs, search for wheel hub test, and rule out your u joints.
additionally lookup how to install "lugcentric" wheels and try again.
if all that checks out, then go to hunter road force balance.
or get a shop to do it all.
VT
To Vibration-common suspects?
