Ring Scraping Cylinder Wall?
Old Jul 19, 2009 | 07:56 PM
LBYRNES's Avatar
LBYRNES
Default Ring Scraping Cylinder Wall?
I just started putting the pistons back in my '93 LT-1 and there is a scraping sound when I turn the crank over. Looking at the photo below there are three scratches. The piston and cylinder are well oiled. Is the ring scratching the cylinder, or is this normal?
Old Jul 19, 2009 | 08:07 PM
jhammons01's Avatar
jhammons01
See how they are V shaped?? that was from installation. You just didn't notice until now.
Can you catch your finger nail on it?
Old Jul 19, 2009 | 08:38 PM
LBYRNES's Avatar
LBYRNES
Can't actually feel it with my finger or fingernail.
Old Jul 19, 2009 | 08:49 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
it's normal for new rings to make a scraping noise. Be sure you don't dip the pistons in oil, or your rings will take longer to seat.
It is preferred to oil the cylinder, and install the pistons dry.
I f you will be storing this engine, it is permissible to use marvel oil in the spark plug hole and the engine turned over withouth the plugs in. just don't put in too much.
Old Jul 19, 2009 | 09:12 PM
LBYRNES's Avatar
LBYRNES
Thanks. I believe that was it alright.
Old Jul 19, 2009 | 11:51 PM
hip's Avatar
hip
Default ring scraping
It would be a good time to check to see if you broke a ring before you get motor together. If you suspect a certain piston go for it. It would be sad to hurt engine for a $5 ring
To Ring Scraping Cylinder Wall?
