Wheel restoration?
Old Jul 20, 2009 | 06:21 PM
C4vettrn's Avatar
C4vettrn
Default Wheel restoration?
The chrome on my ZR-1 wheels is coming off on all my wheels. The inside is the worst but the faces are starting to do the same in small areas. My question is can chrome be striped in any way like sand or media blasting? If so I would restore to the Grand Sport look i.e. powder coat black face and polished lip or if I can't polish the lip just powder coat the entire wheel blak. What ya think? am I
Old Jul 20, 2009 | 08:50 PM
WVZR-1's Avatar
WVZR-1
I would take a loss on the wheels you've got and sell them for "track wheels" or maybe "hose reels"!
Re-plating chrome is "next to never" accomplished. It's not environmentally friendly to strip the chrome to be able to re-plate them.
You would have many times the price of replacement wheels I believe to accomplish the project.
Someone is going to come by and say just drop them in a bucket of acid with a low-voltage/low amp power supply and it will strip them. That's pretty much the reason it's not done commercially any longer. You need to be able to dispose of the acids etc.
Can you blast them and refinish? Maybe but it will require some specialty primers to adhere to the plating. Most anything is "doable" but maybe not economically!!
Old Jul 20, 2009 | 10:07 PM
jhammons01's Avatar
jhammons01
^^^WHA???
Sorry WVZR, wheels are re-plated all the time. Any chrome plating shop has a "polish" Room. In this room the wheels can be striped with buffing wheels and compound.
Triple Nickel Chrome goes through many steps of plating and polishing before they are done.
Adhesion of Chrome is just like anything else, the surface prep is what counts.
If you take your tires off and drop it off at a real chrome plating they'll have them done in no time. Will it cost a bit more than $25 each??? Yes.....but you need to shop around and get quotes.
Old Jul 20, 2009 | 10:10 PM
jhammons01's Avatar
jhammons01
Here OP, Go here
http://www.reckonplating.com/gallery.php
They have a complete synopsis of what I am trying to relay under the "process" tab
Old Jul 21, 2009 | 04:21 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by jhammons01
^^^WHA???
I'll stick by my comments!
I mentioned "NEXT TO NEVER" and "ECONOMICALLY" - I didn't say couldn't! I also assumed that my comments were being applied to an "inexpensive" process that is used to plate "cast aluminum" automotive wheels.
If you're interested in "DISPROVING" my comments take some of "YOUR TIME" and post back with some quotes from platers with prices for "RE-PLATING" "CAST ALUMINUM" automotive wheels!!!
Old Jul 21, 2009 | 09:14 AM
C4vettrn's Avatar
C4vettrn
Default prep!
I believe that is what happened. These were prob a set of cheaper wheels by some aftermarket co. and the prep work wasn,t the best especially on the inside
To Wheel restoration?
